Fukushima
  • Keep up the good work, I count you as my primary source of info on this subject
    • Comment
      • Title: Another strontium leak at Fukushima nuclear plant
        Source: NHK
        Date: Thursday, April 05, 2012 10:23 +0900 (JST)
        Tokyo Electric Power Company says more radioactive wastewater has leaked from its Fukushima Daiichi nuclear plant. The water contained high levels of strontium.
        [...] the company says some of the wastewater may have flowed into a ditch leading to the ocean.
        TEPCO has apologized for the incident and says it will determine the cause and extent of the leakage. [...]
        Title: Strontium at Fukushima plant flows into sea
        Source: NHK
        Date: Thursday, April 05, 2012 12:34 +0900 (JST)
        [...] TEPCO says about 12 tons of wastewater leaked from a disconnected joint in the pipe. The company also says it believes that a large portion of the water has flowed into the ocean through a nearby drainage ditch.
        The utility is trying to determine how the joint became disconnected, and how much water poured into the sea. [...]
        Japan nuke plant leaks radioactive water again
        Source: AP
        Date: April 5, 2012
        -Tepco spokesman
        Cyanobacteria over 1,000,000 Bq/kg outside Minamisoma City Hall
        Normally blue-green algae in south Soma city is black...
        Source: Minamisoma city council member Koichi Oyama
        Date: April 4, 2012
        1) 405,000 Becquerel /Kg before the headquarter
        南相馬市の黒い藍藻分布①本陣前 - YouTube
        2) town city hall 1,080,000 Bq
        南相馬市の黒い藍藻分布②本町108万Bq/Kg - YouTube
        3) Around central post office
        南相馬市の黒い藍藻分布③ - YouTube
        Tritium spreads underground of Fukushima plant
        Posted by Mochizuki on April 4th, 2012
        1.6E+6 Bq/m3 of Tritium was measured from a deep well in the plant area of Fukushima (500m away from the reactor buildings), Tepco announced in their press conference of 4/4/2012.
        Last time they measured beta nuclides from the same well on 11/19/2011, tritium was ND, which shows the underground contamination has been expanding since then.
        From the press release of 4/4/2012, Tepco measured 1.3E+6 Bq/m3 of tritium from the sub drain of reactor 2, and 1.8E+6 Bq/m3 from the one of reactor5, which are the same level as what they measured from the deep well.
        As to tritium, underground water is as contaminated as sub drain of reactors.
        Marine contamination reached Philippines last April...
        Kobayashi fellow-researcher from Japan Atomic Energy Agency analyzed that 18,000 trillion Bq of Iodine 131 and cesium 134 + 137 directly leaked from Fukushima to Pacific ocean.
        However, because it is the estimation after 3/26, it would be much more than that if it includes what leaked from 3/11 to 3/25.
        Also, it will be a several times much as 18,000 trillion Bq to count the radiation to fall from air down to the sea.
        From their simulation, marine contamination already reached Philippines by 4/10/2011, will reach Hawaii by March of 2014, where is 5300 km away from Fukushima.
        Madness
        Japanese 'Ghost Ship' Off B.C. To Be Sunk
        V
        General D.Eisenhower
        http://www.nvtronics.org
        • Interesting that this video has been deleted
          I wonder if it really was deleted by the user or was it youtube?
          • Statement by Akio Matsumura:
            The crisis at the Fukushima-Daiichi power plants has not ended. While the first three reactors contained fuel and presented a serious threat since March 11, 2011, they have largely been contained. Reactor 4 contained no fuel when the earthquake hit. Instead, the spent fuel rods had been moved to a cooling pool on the second floor of the containment unit. [...] If another high level earthquake hits the area, the building will certainly collapse. Japanese and American meteorologists have predicted that such a strong earthquake is indeed likely to hit this year.Title: Fukushima Reactor 4
            Uploaded by: christopherjamescote
            Date Uploaded: Mar 8, 2012
            Description: Akio Matsumura talks about nuclear power plants, spent fuel pools, and the trouble with Reactor 4 at Fukushima.
            • an issue of human survival...
              Fukushima Daiichi Site: Cesium-137 is 85 times greater than at Chernobyl AccidentMany of our readers might find it difficult to appreciate the actual meaning of the figure, yet we can grasp what 85 times more Cesium-137 than the Chernobyl would mean. It would destroy the world environment and our civilization. This is not rocket science, nor does it connect to the pugilistic debate over nuclear power plants. This is an issue of human survival. [...]
              V
              • I just received this link couple min ago - Jimstonefreelance.com - Did the Dimona Dozen murder the Fukushima 50?
                V
                • Originally posted by mire View Post
                  There should have been urgency for all governments of the world to have helped them when it was needed last year.. The japanese refused help and told Green peace to get lost.
                  Now that we near the 03-11-2011 anniversary there is even greater concern.
                  If a 3rd great quake was to happen between march 23 and april 10 2012 and it did find japan once again, i would think the people of that country would want answers. I hope they would ask why.
                  My research as to the cause of the great quake is not important, but if it was a annual occurrence then all the governments have lied to all the people of the world..
                  That is Crazy.
                  Baja California, northern Cali, japan, chili, and Siberia. any one of these can have the next great quake IMO.
                  I hope this is not the case, but the evidence tells me there is at least an 80 % chance of another great quake close to 12 days after march 11.
                  1 Feb 27 2010 2 March 11 2011 3? March 23 2012?
                  just want to say thanks for the updates.
                  Does the world really want answers? the truth?
                  I would hope so after this..
                  peace all ..
                  • Nitrogen injection temporarily stops at Fukushima Daiichi reactors
                    Source: Kyodo
                    Date: April 13, 2012
                    Tokyo Electric Power Co. said the injection of nitrogen gas into three nuclear reactor containers [...] stopped temporarily after 1 a.m. Friday.
                    The company has continued injecting nitrogen gas into the containers of Nos. 1, 2 and 3 reactors to prevent a hydrogen explosion. After using a backup system the injector resumed [...]
                    This is the fourth time since March that the injection of nitrogen gas has stopped, the company said. [...]
                    Nitrogen injection stopped again
                    Source: Fukushima Diary
                    Date: April 12, 2012
                    Tepco sent another emergency email to the journalists at 04:18:37JST 4/13/2012.
                    [Translation]
                    At 1:30 of 4/13/2012, Tepco staff confirmed nitrogen injection equipment was automatically stopped because it was alarmed that the air compressor went out of order at 1:04.
                    At 3:10, nitrogen injection was restarted by using another nitrogen injection equipment. [...]
                    21:56 JST 13 Apr 2012 21:52 JST 13 Apr 2012 Fukushima-ken Oki M3.6 1
                    21:33 JST 13 Apr 2012 21:30 JST 13 Apr 2012 Ibaraki-ken Oki M4.2 3
                    21:20 JST 13 Apr 2012 21:15 JST 13 Apr 2012 Fukushima-ken Oki M3.4 1
                    21:16 JST 13 Apr 2012 21:12 JST 13 Apr 2012 Fukushima-ken Oki M5.2 3
                    20:09 JST 13 Apr 2012 20:04 JST 13 Apr 2012 Fukushima-ken Oki M4.0 1
                    19:38 JST 13 Apr 2012 19:33 JST 13 Apr 2012 Fukushima-ken Oki M4.1 2
                    19:21 JST 13 Apr 2012 19:16 JST 13 Apr 2012 Fukushima-ken Oki M4.5 2
                    19:21 JST 13 Apr 2012 19:10 JST 13 Apr 2012 Fukushima-ken Oki M5.9 4
                    Also - Odd tube wear seen in both Onofre reactors
                    Source: The Orange County Register
                    Author: PAT BRENNAN
                    • radioactive water spill at Limerick nuke plant
                      NRC reveals radioactive water spill at Limerick nuke plant
                      Source: The Mercury
                      Author: Evan Brandt
                      • Edano: All reactors temporarily offline in May
                        Source: AJW by The Asahi Shimbun
                        Date: April 16, 2012
                        • This time from Australia...
                          Vomiting road workers hospitalized after exposing mysterious nuclear waste
                          Source: Fox News
                          Date: Apr 18, 2012
                          Workers sick amid highway radiation scare
                          Source: ABC Australia
                          Date: Apr 17, 2012
                          • Originally posted by blackchisel97 View Post
                            good news and thank you blackchisel97 for the update .... but i'll keep an eye on the sun on may 6th or any other astral alignement ... not sure but you never know ... all truth is but half truth
                            btw: a nice principle of correspondence: Japan to burn radioactive debris
                            Keiser Report: Meets Schiff Report 4.0 (E276) - YouTube
                            Signs and symbols -Confucius.
                            • "We falsified data"
                              Former Fukushima Daiichi Reactor Operator: We falsified data and rewrote daily operative reports (VIDEO)
                              Interview with Toshio Kimura
                              Translated by: Goldieluvmj
                              Date Published: Apr 13, 2012
                              At 0:48 in
                              NARRATOR: Kimura used to operate the reactors and maintained the fuel rods at the Fukushima Daiichi nuclear power plant. He confessed that TEPCO has deceived the government, which regulates the nuclear power plants, in a number of ways.
                              KIMURASee English subtitles by clicking CC button in YouTube toolbar.
                              My thought on restarting the nuclear reactors - YouTube
                              Lessons Learned From Fukushima Dai-ichi (1. Press Conference. 2011. 10. 28)
                              Author: Kenichi Ohmae, Nuclear engineer
                              Date Uploaded: Mar 21, 2012
                              Uploaded by: by H2OProjectBBT
                              As a nuclear core designer and someone who earned a Ph.D. from the Massachusetts Institute of Technology in nuclear engineering, I volunteered to look into the situation at Fukushima No. 1 in June of 2011. Mr. Goushi Hosono, minister of nuclear power and environment, personally gave me access to the information and personnel who were directly involved in the containment operations of the postdisaster nuclear plants. After three months of investigation, I analyzed and wrote a long report detailing minute by minute how the nuclear reactors were actually disabled -Japan Times
                              At 11:20 in
                              Kenichi Ohmae, Nuclear Engineer: This is sheet two. This chart shows equipment loss of all the nuclear reactors such as power supply of AC/DC.
                              Therefore, there may be many people with the impression that Fukushima Dai-ichi reactor 1 to 4 are in the most severe difficulties, but actually, other reactors are all in considerably severe condition with the external power, or emergency power devices.
                              The red marked devices are broken.
                              Regardless of such extreme situations, though not much has been broadcast, as you will find in the sheet, in all reactors except for one, two, three, and four of Fukushima Dai-ichi, cold shutdown occurred well until the end.[...]
                              Special thanks to: Ms Jewel Naruse Ms Seiko Toyama Mr. Curtis Hoffmann Ms Keiko Sato
                              Lessons Learned From Fukushima Dai-ichi (1. Press Conference. 2011. 10. 28) - YouTube
                              V
                              • SAN ONOFRE: Nuke plant tube inspections complete
                                Source: North County Times
                                Date: Apr 20, 2012
                                [...] Meanwhile, a fire in Unit 2′s electrical panel on the non-radiological side broke out Friday, but it was extinguished in less than an hour. No injuries were reported.
                                The cause of the fire is under investigation.Title: Small electrical fire reported at San Onofre
                                Author: PAT BRENNAN
                                Date: Apr 20, 2012
                                Title: SAN ONOFRE: Nuke plant tube inspections complete
                                Date: Apr 20, 2012
                                Inspections of faulty tubes that caused the shutdown of two reactors at the San Onofre Nuclear Generating Station have been completed, but findings are not yet being released, Southern California Edison said Friday.
                                the truth is always hiding there in plain sight: "unexplained" - "unknown"
                                In other words: "No clue" - "uncontrolled"
                                V
