re post
Here is a very nice website: good for your magnetized water and for the fertilizer apparatus (see above picture )
OSnano
Open Source Nanotechnology
Step 1: Prepare and Collect Ingredients
(a) Ingredients for a typical nanocrystal synthesis include: Oil, vinegar, pan, crystal drain openerTM and rust.
Step 2: Make your own soap.
(b-c) Synthesis begins with soapmaking. For this the oil is mixed with crystal drain openerTM and water.
(d) After curing for a day the soap solidifies.
Step 3: Produce a Fatty Acid Mixture
(e) For efficient dissolution in subsequent steps, the soap is ground to a fine powder,
(f) then mixed with vinegar
(g-h) while heating on a stove.
(i-j) Once all the soap is dissolved the solution forms two layers: a yellow top layer and a cloudy white/yellow bottom layer.
(k) The top layer is the fatty acid mixture (FAM). This needs to be heated at 110 oC to remove excess water and vinegar by-products.
(l) Clear yellow FAM is collected.
Step 4: Collect and Grind some Rust
(m-n) Rust was scraped off of rusted metals and was ground to a fine powder.
Step 5:Cook/grow your own magnetite crystals
(o) FAM and rust were mixed.
(p-q) Mixture was heated for 2 hours at below and near boiling temperatures. The temperature was measured using a standard mercury thermometer.
(r-s) Magnetite (black) began to form.
Step 6: Verify your Magnetite Crystals
(t) TEM micrograph was obtained after magnetic separation in chloroform. Scale bar is 50 nm.
step 6 (i don't think we care that much about it )
OSnano
At this stage, it consists of only one project: instructions for creating magnetite nanocrystals; but we hope this project will inspire others in the future. What can you do with magnetite nanocrystals?
Why? Magnetite Nanocrystals are good for removing arsenic from water
...but the following pictures taken from the painting kept bugging me:
)to hear someone replicate the double Mobius Caduceus Coil experiment ..it is really simple...and heats water quite fast but i have no clue what happens...call it inspiration when it was built...
you made my day
