  • and so I figured I'd take a look at 369 Magic Square...found the following
    The numbers associated with the Moon are 9, 81, 369, and 3321. This is because: Each row and column of the magic square contains nine numbers.
    The square contains 81 numbers total, ranging from 1 to 81.
    Each row, column and diagonal adds up to 369.
    All of the numbers in the square add up to 3321.
    Moon Magic Square - Magic Square of The Moon - Lunar Numbers
    the Seal of the Moon: Planetary Seal of The Moon
    In the Western occult tradition, each planet can be represented by a seal or diagram. The seal is based off of the planet's magic square, with the seal theoretically touching every number within the square, although in practice that is not always apparently the case.
    As drawn here, the seal actually does intersect with every box of the magic square of the Moon. However. as commonly drawn, there are actually several squares that are not included.
    Like the seals of Mars and Venus, the seal of the Moon is based off a magic square with an odd number of boxes per row. Also like those two seals, this seal commonly does not include all boxes.
    However, the seals of Mars and Venus are asymmetrical, and while they bear many similarities with each other, they bear far fewer visual similarities with the seal of the Moon.
    It may be more helpful to compare the seal of the Moon with that of the Sun, as Sun and Moon are commonly seen as a pair as the great luminaries of the sky. Both seals are comprised of two large, intersecting diagonals, and both contain four crescent shapes. The crescent shape is particularly appropriate for the Moon, which frequently appears as a crescent in the night sky. The common astrological symbol for the Moon is also a crescent.
    Donald Tyson suggests that the 13 small circles in this seal may correspond to the 13 lunar months that are in a year. However, since he considers those circles to have only aesthetic value in the other seals, this may very well be coincidence.
    Signs and symbols -Confucius.
    • the seven seals based of there respective Magic Square:
      Black Tourmaline
      Ruling Planet: Saturn
      Auripigment:
      Ruling Planet: Mercury
      Magnetite:
      Ruling Planet: Jupiter
      Moonstone
      Ruling Planet: Moon
      Copper
      Ruling planet: Venus
      iron
      Ruling Planet: Mars
      Quartz:
      Ruling Planet: Sun
      • From: http://www.energeticforum.com/renewa...netism-55.html
        I was wondering where the 6 went, in this system...60 hz...harmonic math 60 is 6
        42712.2 x 9 = 384409.8 Hz
        384409.8 x 3 = 1.153229.4 MHz
        COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
        An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
        . a harmonic cascade effect
        I was just reviewing some numbers posted in this thread and started with
        an info posted by Prof Savic : http://www.energeticforum.com/renewa...r-query-2.html
        1.725mm electrode distance is 60 Hz. 300 Hz and the negative electrode has to play the sonic boil
        Reduction is one of the method used in Harmonic Math (also called Rodin Math )
        1.725 = 1 + 7 + 2 + 5 = 15 = 6
        60 Hz = 6
        300 Hz = 3
        I think 2.1mm was the space between the can and the ring so the ring should be 70.2mm
        2.1 mm = 3
        70.2 mm = 9
        I hope you see the Pattern...just find the 3 6 and 9
        last but not least:
        Early in this thread, Prof Savic wrote that the inside diameter of the beer can was very important because it had to be the quarter wave length of the frequency 1.1530479 MHz
        1.1530479 MHz = 1 + 1 + 5 +3 + 4 + 7 + 9 = 30 = 3
        I think you'll Appreciate this one:
        Sonic boiler are trying to make a 110 Volt 60 Hertz has a COP = 6.93
        What you supply area of the apartment, you calculate the width and thickness of the electrode, zero reba to resonate at 300 Hz. Fuse will die if you are using electricity for over 15 Amperes.
        300Hz = 3
        15 Amp = 6
        a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
        • a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
          If you understood the above statement , you'll understand the following
          just on a side note: the double spiral water closely resembles the double mobius coil mentioned earlier
          Step 1
          2 wires of six feet each to be made into 2 mobius wires (you end up with 2 mobius wires that are 1/4 the length of 6 feet )coiled at 45 degrees (see how to build a mobius coil Mobius Coil Tutorial )
          Step 2
          Coil the first Mobius Wire as previously indicated in a Caduceus Manner (three times / three crossing maybe )
          Step 3
          Coil the Second Mobius wire 180 degrees opposite of the first Coil
          Step 4:
          Connect as previously indicated http://www.energeticforum.com/renewa...-query-43.html start with post #1271
          enjoy the experimentation
            The frequency you would need frequency 528 Hz (DNA repair frequency ?) : NO MUSIC single tone - YouTube
            I believe it could be done, would be a worthwhile en devour, after we get FE I will go in this direction.
            Tesla found that the electric field healed the body, I probably read it in one of your posts
            found this here:
            Letters=numbers=sounds=colors=shapes
            Note: Purple corresponds to 540 hz
            while doing some research, i found the following:
            holistic living center
            • A little interesting background history:
              The Magic Square was given to mankind after the Great Deluce by a Mythical Entity, Half Man, Half Serpent. He came from an old civilization that was situated in MU. His Knowledge came from the Star System Orion (The Turtle).
              The Egyptian name of this Magical Entity is Thoht, Tehuti or Djehuti. The Greek named him which relates him to the number 15 (3X5) of the Magical Square. Thoth was the keeper of the Secrets of Osiris (The Planet Sirius). Thoth was the Moon-God and is represented in old paintings as ibis-headed with the disc and crescent of the Moon
              Nothing is @ Random
              The Old Chinese Masters made a distinction between the Square and the Circle. The Square was related to Human Creativity (Playing the Infinite Game of Life). The Circle was related to the Cycle and the Spiraling Spiral, the Fundamental Laws of the Universe.
              The meeting of the Square, The Game, and the Circle, Fate, generates Luck, Coincidence or Synchronicity.
              just have to pay attention
              • also within the same link:
                The 5 represents the Center and is called the Force of Life (Chi). Chi was called Ether in the West and Prana in India. Ether is called the Vacuum in Modern Physics.
                The Magic Square is a representation of a Topological Structure called the Moebius Ring. The Ring is a Cyclic Structure without a Boundary. The Ring is the Basic Fractal pattern.The Universe is a Closed Self-Referencial structure, a Spiraling Spiral. The Ring enfolds in a Ring and the Enfolding is a Ring.
                here is a nice vid linking Rodin Coil and Magic Square : (was mentioned in the the golden tractate thread )
                lo shu Magic Square / solfeggio code Matrix Vid1 - YouTube
                also you may want to go here too:
                David Icke's Official Forums - View Single Post - The Vortex Maths - Marko Rodin Thread
                also this one:
                Lo Shu Solfeggio code. I ching to Ho Tu to math introduction. Sum of things.. - YouTube
                • I must learn this secret of 3, 6, & 9.
                  It is not really a Secret...It is more of an Understanding of a Concept....Think of it this way...Analogy...it is as if you are used to seeing light in a normal way then to change perspective you put on Night vision Goggles
                  As evolvingape Said
                  Sorry, but I cannot tell you the secret, I can only show you... you must find it for yourself...
                  you'll have to learn to visualize your acquired knowledge under a different light
                  • A bit of child like curiosity will take you a long way
                    Remember to a Child Everything is Possible...because he has Imagination...to him the fantastic things seen on tv exist..and he will argue you on that..
                    In other words:
                    National Geographic Channel - IF. Live curious. - YouTube
                    If you are, you breath.
                    If you breath, you talk.
                    If you talk, you ask.
                    If you ask, you think.
                    If you think, you search.
                    If you search, you experience.
                    If you experience, you learn.
                    If you learn, you grow.
                    If you grow, you wish.
                    If you wish, you find.
                    If you find, you doubt.
                    If you doubt, you question.
                    If you question, you understand.
                    If you understand, you know.
                    If you know, you want to know more
                    And if you want to know more, you are alive
                      The Math of the I Ching (or magic square if you prefer )opens The Well (Field Pattern) The This Field Pattern is then found in - The Grail Quest,
                      the division of the waters (the moon rules the waters) the tyrant of darkness was overcome, as the light/energy rose-up within the Earth (matter) to create all things. The people (parts or forces of nature - demonic pantheon) were then able to inhabited the Promised Land (that was built or rested upon the Sacred Mountain). But to remind the people of the time of darkness and toil, at the time when the dark was full or greatest the people held the Ceremony of the Sacrifice (this being the Winter Solstice - the time of Return), and at this time they called upon and gave reverence to their Ancestors who had sacrificed themselves in order to give their children life. The feasted on the meat of the boar and pheasant, which was cooked in the vessel (Caldron), and they stood before the king who gave his judgments of the law.
                      are linked to the coming of the light through the law of physics. The readings give a means to produce physical movement of the body through its lines of energy or Chi, which we view as psychology (in mind). The union is between the body (matter), and mind (energy), between water and fire, as through the law or will of Heaven all things are balanced in the middle point of observation - the single point of observation is the inner eye or single gate, as all opposite movements of duality. If the balance of created movement is not maintained, as it is not when the middle position is lost to our knowledge, nature swings too far against its opposite sides (sides of the Well - source) and then the vessel breaks apart. .
                      if you read the Kybalion...you'll recognize the above mentioned statements
                      • From the same link
                        In the I Ching it says: The steps therefore are states of awareness of the creative process within the body that is constructed in the 6 steps, and upon the attainment of the 7th level the sage allows universal wisdom (the law) to move matter, while he rests in a state of clear awareness in the 6 centres or Chakra of physical movement (the movement is on 384 lines of energy). The 6s and 7s are found in the 9 x 9 Magic Square of the Moon in which the constant flow of 10s gives the total of the integer pairing 1 to 9, 2 to 8, 3 to 7, 4 to 6 in each decimal step 1234(5)6789. The total of each expansion is given as an average value in 5 and the total of 10 + 5 = central values of the 5 Element or Direction (into which the 10 Cyclic Signs fit). The x 6 gives the value of The Binary Trigrams or Trines, the Binary expands = 124875(10 = 1 = 64)24875 in the bound-up Torus 1 to 10, as in 3 6 9 and 9 6 3.
                        hope this shades a bit of light....pun intended
                        • Here is a very nice website explaining the origins of Yin Yang: Early Heaven
                          Chinese Legend tells how, around 3,320 BCE, the elderly sage Fu Xi was desperate to devise a way to transmit his lifetime's store of wisdom to his people and their descendents. His inspiration came when he was beside the Huang He, the Yellow River, and he saw a wondrous dragon-horse rising from its depths.
                          I had seen the Taiji Tu shining in the heavens: it was in the moon.
                          find the correspondence with the lines
                          Although the half moon gua are not exact images of the phases they represent, they are even more remarkable: the proportion of yin and yang lines reveal the movement of the phase. The waxing phase, where the moon is becoming lighter towards fullness, has two yang lines and only one yin line; neatly depicting the increasing importance of the light. The waning phase, on the other hand, has two yin lines and only one yang, revealing its movement towards shadow.
                          The waxing and waning of the moon is analogous to both the annual solar cycle of summer and winter, and the daily rhythm of day and night. The mapping of both the year and the day onto Fu Xi's circular arrangement is simple and straightforward (although we need to remember the Chinese traditionally place south at the top of their maps, not north as is the custom in the West).
                          this is another example of:
                          • follow up: the next commentary is embodies very well many posts we have discussed
                            Principle of polarity
                            Opposites are common: white and black, summer and winter, day and night, new and old, above and below, and so on. And it is easy to see that there is a half-way point that is neither quite one nor the other: grey, spring (or autumn), dawn (or dusk), middle age, the middle ground.
                            The Daoists, like many Oriental philosophers were intrigued by the idea of the middle way, and instinctively distrusted extremes. Even peace, if pursued as an end in itself, could lead to inactivity, lethargy and decay, resulting in death just as surely as war (and that's if the peace movement hadn't already become intolerant, fanatical and militant and, thereby, self-defeating).
                            An ultra thin line separates the yang from the yin on the Taiji Tu. Arguably, the width of this line is no greater than that of the momentary present separating the past from the future. Yet it is on the cusp of this line that we experience life. The interactions of opposites produce the infinite complexity of the universe.
                            • One more info i forgot to post: Leonardo Da Vinci Mathematician! His studies in higher mathematics!
                              MUSIC AND LEONARDO DA VINCI PAINTING
                              Music is closely linked to mathematics in terms of the rhythmic patterns a piece of music can employ. Leonardo understood this. In the painting of the Last Supper, it was recently discovered that the proportions of the Last Supper painting were mathematical in nature (apart from the use of a vanishing point), which derive themselves from the musical equation of 12:6:4:3.
                              If measured in equal units, the paintings' size is 6 by 12 units. The back wall measures 4 units and the windows are 3 units. In terms of the musical equation, 6:12 represents an octave, 4:6 denotes a fifth and 3:4 is a fourth. Leonardo left clues to his thinking with the following quotes, 'resonance between visual and aural harmonies' which shows he saw a correlation between the two (painting and music) and 'offer praise to the harmonies of the universe' was used to signify his intention of using the equation proportion. Within the painting, music melds the harmonies of the paint and mathematics.
                              he also understood the principle of the spiral (or caduceus):
                              alchemical illustrations
                              and i suspect he also knew about this
                              • Do you guys recognize this : http://www.bl.uk/onlinegallery/ttp/ttpbooks.html
                                Peter Davey Sonic Boiler Patent fig:
