Use for the Tesla Switch
  • I really want to see a good gain in my batteries so my next experiment will be a 6 battery set up.
    I'll be using the 3 battery TS. My load will be 3 energizers. Which from what I can see from what others are using as a load hopefully wont be too much of a load. I've already used 1 energizer as a load and appeared to be gaining in total voltages. So I'll be adding basically 2 more energizers to my current set up, which should speed up the testing a little. That will give me 4 charging batteries and 2 "run" batteries.
    I'll rotate the batteries which will give me 2 charging cycles to 1 discharging cycle and see if I can get an over all gain. I know this will be a hassle rotating batteries and may not work but its a simple test that "I" can do to see if I can get a gain. Unless things can get a little simpler for a novice like me its about the best I can come up with for now.
    Keep plugging away guys I'm sure one of you will get this figured out.
    Mark
    • Here it is, The D-TS that is.
      Team, take a look.
      YouTube - Working D-TS.MPG
      Bit's
      • Bit's link is not working
        Kev
        • Originally posted by redcar1957 View Post
          Kev
          Keep trying, I checked it out. I think the youtube server is busy with this one. There has been 27 views in about 5 min.
          Thanks Kev.
          Bit's
          • Originally posted by Bit's-n-Bytes View Post
            Team, take a look.
            Bit's
            This is great news Bit's-n-Bytes!
            I have a few questions after watching that...
            - What circuit arrangement are we seeing here? 2 switch with diodes?
            - What is the rating on your bulb loads?
            - How long has it been running and have you got some voltage measurements over time that you can share?
            Thanks in advance if you can answer any of those, and I hope it keeps on charging under load indefinately for you.
            • congrats!!!!!!!!!
              Looks like you may have gotten it Bits!!!!!!!
              Kev
              • Originally posted by downunder View Post
                The circuit is in this post #1468
                Bulbs are 1157's
                Too soon to tell on the measurements. I pulled the batts out of the garage (more like the deep freeze). Will post more results when I get them.
                Bit's
                  Bulbs are 1157's
                  Bit's
                  Hey Bits, looking good.
                  I removed all but the serial transistors (reversed direction) and put in a serial diode before the two that branch to the positives of the batteries on the other side. It makes a HUGE difference not having the other transistors in there, don't know why exactly yet, but I'm using 1.5 ohms 22W as a load on both sides. Transistors don't like a big duty cycle, not even 50%, they start to get a little hot at 50%, so I've got them down around 30%. Batteries seem to be charging, but we shall see in the morning.
                  Leroy
                  • Way to Go!
                    Hi Bits,
                    Congrats - a really intense effort - way to perservere.
                    Plazma
                    Yep - 4 semiconductors, 4 DOuts - 4 separate Optos - 2 of your semis on top look like pnps - not sure - way to go!!!
                    Team, take a look.
                    Bit's
                    • Tesla Switch
                      Bit's,
                      That is real good, that is what mine does. when I look I see that one light is a little dim, one a little bright. That is the imbalance in the cells. You have done a good job. as I said in the beginning I do not like to use the word current. But that is what the Tesla switch is, swapping currents. I will keep watching. Thanks for posting that. Should be easy now to put two transformers in place of the lights with rectifiers to charge caps to run something. Slow charge magneto.
                      JB
                      John Bedini
                      www.johnbedini.net
                        Bit's,
                        JB
                        John /et all. Thank you. This is why this forum is so great. There is so much to learn and the great minds that all contribute.
                        "Work from one, should be shared by many"
                        Bit's
                        • Tesla Switch
                          Just though I would let you all know, Scalar wave tuner is off the scale in the geo-magnetic area +100, we must be in for some huge earth movement. Last time I have see this was the Sylmar earthquake. Tuner pointing towards the south of Idaho, I'm 90 miles from Canada. Again Excellent work Bit's, we need to talk about some work we need done here.
                          JB
                          John Bedini
                          www.johnbedini.net
                          • Tesla Switch v2.2.3
                            For years i have Seen John endure a lot, i cant believe my eyes it looks like he is finally going to get it off the bench. Congrats to Rick and John what a great day.
                            Guys here is a quick Link
                            Tesla Switch v2.2.3
                              JB
                              Whatever is happening up or below, lets hope will not be as bad as Sylmar. I'm more and more hesitant to blame Mother Nature for those events.
                              @Bit's . Excellent work and admirable persistance
                              Vtech
                              General D.Eisenhower
                              http://www.nvtronics.org
                              • 7.0 Quake Devastates Haiti!!!
                                Hi John -
                                Heck of an instrument you have - check this out on Yahoo . . .
                                Plazma
                                Port Au Prince destroyed!
                                JB
                                Last edited by Plazma; 01-13-2010, 05:49 AM. Reason: More info Haitian Quake hit 4:53PM (EST?) - so, is JB picking up aftershocks or something else?!
