All transistor TS
Hi nvisser,
It is interesting that you should post about that circuit as I am just about ready to go back to it. I thought I had given at least one report on it. Sorry if I forgot. I did get that circuit to run all the optos and the output driver chip on the picaxe18x project board all night long (over 8 hours) and it did not run down the batteries even as much as .01 volts. They read exactly the same the next morning as they did when I started the test the night before. The picaxe18x project board allows you to separate the output driver chip from the pic chip so you can use a higher voltage to get the optos to turn fully on and thus also your main transistors. So the only power outside the TS was the 3 AA batteries that were powering the pic chip itself. By the way it must use a small amount of current as I have been using those 3 AA batteries for weeks now and they are still strong.
After a couple of weeks of trial and error (mostly error) I was never able to get the batteries to actually go up in charge although I could run different loads on them without them going down if I was careful about my on time and left enough off time. At that point I decided to order some schottkey diodes and try a slightly modified version of the circuit with all the diodes. I have not had any better luck getting the batteries to actually charge with that circuit either. I did learn something about the picaxe18x chip though. I can use a pulsout command to get an on time as short as .01 ms. I am still learning about the picaxe18x chip. By using this command and an off time of 100 to 500 ms I can get the batteries to bounce back a little higher than they were and then they stop. I think they are just rebounding from being used although I usually let them rest to stabilize before I start any new tests.
John K. posted some interesting info about how to determine load size for the TS, so I think I am just about ready to go back to the circuit without any diodes. I will then set up the pic for a real slow time and take the measurements John K. has suggested. After getting the load right I am going to try and use the pulsout command to get very short on times and vary the off times to see if I can get charging. I am pretty sure that without the diode drops we can use a larger load and with the short pulses maybe get some charging.
Oh I almost forgot. The way I ran the TS all night on it own power was to use a bridge as the load and charge a 21,500 mf cap and run the circuit off the cap. I think I used about 25 ms on, then 100 ms off, then switch sides and repeat.
Hopes this helps some, Carroll
Hi nvisser,
Did I read this right?
) tells me I wasn't going anywhere so I pimped my D-TS to have all four batts at 24V...
