Great!
Hello there Dana!
Ok, I am assuming it was at 36V there...
Now, the Diodes, you connect them at both Positive Negative, blocking reversed currents from Motor to Batteries...right?
Mines (NTE576's) Don't hold on that much "heat"...they blow like 5V fuses on a 1000 Watts lamp...
Your Diodes get hot?
Yeah, there is something wrong there Dana...it should go higher than 3670 at 60V...
Let me just ask a silly question:
Your Batteries Bank...are they same Amp/Hour rating...or are randomly a mixed up amperage/hour?
I know you wrote they were Golf Cart Batteries, 6 Volts...but same A/H rate?
Originally posted by prochiro
I added the two diodes on output of P1 and P15 and ran them parallel with 2540 RPM and 13 Amps.
I ran the same setup with 60 volts and she did 3670 RPM and used 46 Amps. But she was screaming while running smooth and scared the cats.
Dana
Dana
[/IMG]
and want me to keep "rubbing it"...
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
