Real or virtual
Thanks Ufo,
I did look up the meaning of virtual. I still fail to see how it actually applies except in your imagination. And there are real photons. It seems virtual photons are used in some calculations. Here is an interesting take on it from Wikipedia:
If "virtual" things conserve energy then using virtual to describe a field delivering free energy is a contradiction. But just words.... Let's see the hardware produce.
Sorry, I don't follow you about gaps. When you see an opportunity, please point out the gap(s) in the device.
Magnetically, the only part of the coil turn (or wrap as some call it) is the part that passes through the center of the doughnut hole.
You left out the most important word in my statement.... MAGNETICALLY. To the magnetic circuit, the mmf derives from only the current passing through the magnetic circuit, as described by Ampere's Law. The wires circling the outsides of the core are just "end-turns" connecting the necessary circuit to enable current in the active conductor which passes thru the ring of flux.
Virtual particles do not necessarily carry the same mass as the corresponding real particle, although they always conserve energy and momentum.
...massless, weightless and transparent Photons...same properties as Spatial Magnetic Fields don'tcha think?
!!...no noise from absolutely no one who is NOT BUILDING like We ALL are!!!
