Reactive Generator Research for everyone to share
  • Hi everyone,
    you may have read that I've been saying this circuit is not creating energy. What I think is going on in this circuit is by causing a time delay between the TWO electricity components (voltage & current) you don't destroy the electricity (aka don't kill the dipole) by short circuit like typical everyday circuit we use.
    When the electricity components are 90 degrees out of phase they can go through a circuit, do work and come back out with next to no losses if there is minimal resistance in the circuit.
    However, you need something to receive the return and store it or convert it to something useful. I think this is what the Alternator Gen is doing. So timing is very important and I'm now starting to think that a permanent magnet alternator gen may not work as well as an exciter rotor field alternator gen like I've been using in my demos.
    Let me explain, for the past 3 days I've been busy converting a DC permanent magnet motor to an AC permanent magnet generator. It's a big job but I got it done and I was testing it last night and found the effect is not as obvious or as good as using an exciter field rotor generator.
    When my series cap circuit is connected to this PM AC gen it's like something is out of timing!... I see the effect a little but it's like it's kind of having a fight inside the gen, like a motor out of timing. So I'm starting to think that the exciter rotor gen causes more of a delay then a PM gen and it could be this delay that makes the difference in helping the gen rotor to be pushed at the right time when the reactive power is returned.
    More tests need to be done but I though I would share this new information.
    Luc
    Also, at the OU topic, user name nilrehob has been doing a lot of experiments with what I have shared and has prepared 2 pdf documents.
    Here is his post:
    Hi Luc,
    As You requested, since I get little time left for experimentation, I have written a short 3-page pdf about what i call "Reactive Impulse". This will be my next area of research. Maybe You (or someone else) will find this interesting and beat me to implement it.
    https://sites.google.com/site/nilrehob/home/documents
    /Hob
    • Hi Luc,
      I don't know if it is the same but something similar happend to me when I tried to make the genny coils of a little monopole motor resonant. As soon as I connected the resonant cap it would suck the motor speed into the resonant lock. It was like the biggest load the motor would see... I'll explain. Let'say the resonance between coil and cap would happen at 3000 rpm. If I would start the motor with the cap connected to the genny coils the motor would slowly get up to speed until the gennys would get close to the resonant point. At that point it was impossible to go any faster and past that point, like a big break.
      On the other hand, if I started up the motor without cap and let it speed up above the 3000 rpm, say 5000 o 6000 rpm, and then connected the cap to the generator coils and slowly decreased motor speed, it would slowly decrease, but when in proximity of 3000 (resonant point) it would quickly start to brake down until below 3000 rpm. It simply was not possible to hold it a resonance as it was the greatest load the motor could possibly see.
      I still do not understand why that is in a rotored pm generator coil, as this doesn't happen if you excite the genny coil with a primary winding.
      Actually, that's not totally true. If you tune a primary to the point where resonance in the secondary is at maximum it will reflect back to the primary big time! Even though current and voltage are 90 degrees out of phase.
      But, if you go decrease the frequency just a bit you will find a resonant point (dip) which doesn't give the highest peak of the possible resonant rise on secondary (just a bit lower) but it will not reflect back to the primary.
      I have never been able to do this on that rotored generator coil setup, maybe I should give it another go..
      I could get the motor coils into resonance with tuned caps no problem though, there you can tune for the lowest consumption.
      Another thing I know now after a few tests is that the core of a resonant coil has to be open, you can't use a normal toroid or closed transformer core.
      regards,
      Mario
      • Hi Mario,
        yes, I don't know if we can compare your circuit to mine
        But thanks for sharing and hopefully we will find answers for all this
        Luc
        • Originally posted by Bob Smith View Post
          I'm not an expert, just someone who tries to think, build a little and reads. My musings for what it's worth...
          Erfinder, If I understand you correctly, you are stating that proper impedance matching may be a viable or perhaps necessary precondition for resonance, particularly with conventionally designed circuits and motors. I believe Bearden says something about impedance matching as necessary for keeping the dipole open in order for a circuit to tap into the vacuum's abundant energy. If ...
          I'm suggesting that by definition resonance is literally the matching of the capacitive and inductive reactance. I'm suggesting that resonance and impedance matching are one and the same. I'm suggesting that according to the textbooks when the capacitive and inductive reactance's are matched, circuit impedance is reduced to the DC resistance of the circuit, this value is under our immediate control.
          Tom Bearden says many things about the dipole. It's not what he says that gets my attention, I don't speak his language anyway. It's those "implied" things that I pick out from between the lines that motivate me. Specifically in an interview when asked about the dipole he made a loose reference to permanent magnets, and how the machines that he has seen work as his theories suggest they should, incorporate magnets, dipoles, which he says we cannot destroy! In the same light, he calls the batteries in systems he is familiar with dipoles as well, anywhere where you have a separation of charge you have a dipole. The language he uses when discussing the topics of impedance matching, Reguaging and dipoles in general leads one (me) to think that he is describing how dipoles communicate between one another.
          I find comfort in viewing L and C as if they were dipoles. The dipole concept as presented by Tom Bearden seems incomplete to me, the link connecting the dipole to its source is never mentioned. Its here were the work of Eric Dollard fills this void. His concept of space and counter space and how they are linked to the energy storage mechanisms of L and C are brilliant philosophically and practically.
          - this 90 degree phase separation between voltage and magnetic current is made possible by impedance matching (which I think Luc's videos demonstrate), and - if this in fact is a viable pathway to keeping the dipole open (which I believe Luc also says in one of his recent videos),
          You're asking me to comment on something that I am not in total agreement with. As can be seen here:
          Inductor AC BehaviorCapacitor AC BehaviorResistor AC Behavior
          So the whole concept of phase shifting for gain isn't really hitting home with me yet. The text, and patents from Tesla indicate one thing and this thread is suggesting something else. I am not qualified to say which is the sought after solution. In situations like these, not even the benched results can be trusted. My bench is giving me mixed results....
          then, we may have the key in order for circuits to not only overcome their own reactive losses, but to access additional energy from the electrostatic environment, might we not?
          I don't claim to know the answer to this one either. The only thing I can say for sure is that when I look back into the works of Tesla he specifically states that he adds capacitance to circuits to neutralize the effects of self inductance, that's it. I find it interesting that Tesla didn't refer to inductance like we do. We find him constantly referring to self inductance and its relation to capacity and frequency.
          I have found that in every coil there exists a certain relation between its self-induction and capacity that permits a current of a given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or in other words, as though it possessed no self induction.
          Coils For Electro-Magnets
          End Quote.
          So what I am after is what Tesla presented, the ability to neutralize the effect of self-induction for a given frequency. Self-induction = Lenz. I believe we are already extracting energy from the so-called electrostatic environment.
          Good point about the transverse EM wave's possible role in the resistance to change in both L and C. Perhaps Eric Dollard's references to the instantaneous nature of longitudinal EM transmission (i.e., unimpeded by resistance to change) in Tesla's work have something to say to this situation now unfolding in this thread. I find it interesting that Tesla's series wound bifi pancake coil and its mutual cancellation of magnetic inductance between windings gives rise to instantaneously propagating longitudinal EM waves capable of broadcasting electricity without losses. Perhaps the 90 degree separation between voltage and current is another pathway to accessing the longitudinal wave/scalar vector phenomenon.
          Much more that I want to say, but I realize the discussion needs to stay focussed. My apologies if I've drifted things off course.Bob
          I feel you on that, I could speculate all day on the different aspects of all of this, but then folks would be justified in demanding that I put up or shut up. I apologize for the tangent.
          • Erfinder,
            Thanks for your thoughtful reply.
            Bob
              From Hob:
              Hi Luc,
              /Hob
              because it is work. Up to this day it is just a statement that phase shift is occurring, but why is this happening and what is the cost of it, nobody explained it. We take this for granted from the text books. And this is the case for both, the inductors and the capacitors.
              If there is any scientific document or anyone can bring more to the debate table, I am more than willing to contemplate to the opinions.
              Until then, great work and great ideas to everybody involved in this along with my best wishes.
              • Originally posted by barbosi View Post
                Hi All,
                the reason why there is a phase change is due to the time factor for the capacitor to charge with voltage in relation to the current passing straight through. This is why the phase angle changes depending on 1. frequency and 2. value of capacitance. With an inductor it is in reverse, voltage passes straight through and the current charges the inductor, values of frequency and inductance apply to phase angle here.
                Here is a little something that should be studied, video and pdf of a mit lecture:-
                Kirchhofs law does not apply with non- conservative fields.
                Here is an explanation
                and here is a video lecture of which go to minute 33 onwards, it will open your minds "or blow them as the case maybe" Cool
                Lecture 16: Electromagnetic Induction | Video Lectures | Electricity and Magnetism | Physics | MIT OpenCourseWare
                Now I have posted that as an item of measurement in our experiments and not to be fuffled by thoughs that think they are simply right or are there to control the few that do find these things or anomilies.
                I have seen cop>1 many times and always has boiled down to keeping current and voltage separated (don't kill the dipole). There are different ways of doing it, but always it is the separation of voltage and current. We have been blinkered all our lives to P=IV which is right, the dipole is dead because P consumed all it's energy (sucked it dry).
                Using the mains supply is no good as the whole system is closed with other users and so the goal posts will move as others plug in an inductive or capacitive load. Using a home generator is the way to go where you generate your own power and can keep the separation of reactive and active power, that separation has to be thought out very well, and I leave that for you to think about, but remember, the supply converted (90 degree phase difference) must not see the FINAL LOAD (which will consume real power) or it will not work.
                regards
                Mike
                • Thanks for the links, I studied them as you said I should and in the end I got this great inspiration from you:
                  Therefore I am pleased to anounce (and I claim the origin of):
                  Barbosi's law - lectures are informative and do not apply with non-conservative minds.
                  Thank you for the offer but I feel that repeting statements learned as truth without understanding the mechanisms behind them, keeps me in the "Groundhog Day". And I want out because I just learned that storks have no involvement in kids making process. At all, can you imagine that?
                  As always I'm looking forward for inspiration from great souls. Might be any relationship between E field and B field being orthogonals and the phase?
                  Something pretty much like this: Magnetics demonstration | Atmospheric Ionization Research What he forgot to mention is the loop is also bent at 90 degrees (or almost)
                  Regards.
                  • Yes, I agree!
                    It's a copy of a post I made at the OU topic where someone has posted that I'm claiming to create energy. Just posted it at all topics to set the record.
                    Thanks for your help
                    Luc
                    • Hi Luc and all,
                      Luc your generator is an exciter generator and from what you show in your videos and your not so good results from permanent magnet generator (which I can confirm) it seems that an exciter generator is the way to go.
                      Here's my question: are exciter generators the same as induction generators?
                      And what type of generator do normal (portable) gas electric generators use?
                      thanks,
                      Mario
                      • Inductive generators
                        Hi Luc and all
                        from what I understand, in inductive generators the exciter only uses reactive power, and these generators love to absorb reactive power as long as it does not get saturated, at which point the output power stops.
                        This is just an observation from reading up on inductive generators.
                        regards
                        Mike
                        • Exciting generators
                          Hi Mario,
                          After the very rude and disrespectful way you were treated on another thread here I hope you don't mind if I try to answer your questions about generators. All of the portable generators that I have worked on were exciter type of generators. I don't know of any reason there couldn't be a portable permanent magnet generator but I haven't seen one. The old type of generator used on cars before the modern alternator were also exciter type of generators. Even the modern alternator is an exciter type of generator although it produces first a 3 phase AC power which is converted into DC by the internal rectifiers (diodes).
                          I am curious also as to why you and Luc seem to be getting different results when using a PM generator as opposed to an exciter type of generator. I will be watching your efforts to see what you come up with. The only difference from a conventional point of view is that the output power of an exciter type generator can be controlled by the exciter current whereas the output power of a PM type of generator is only controlled by the speed of rotation and the load it is driving.
                          To give you a little more information that may or may not be any help to you, the output voltage of a portable generator is determined by the speed of rotation. The output current is determined by the load and the ability of the engine to maintain the rotation speed. In other words for the AC power to remain at the 60 Hz power for use in the US the speed of rotation has to remain constant. So what happens when we add more load and draw more current? The engine governor senses the loss of speed and opens the throttle slightly to allow more fuel into the engine to maintain the power necessary to maintain the speed of rotation for the generator.
                          Respectfully, Carroll
                          PS: The reason exciter types of generators or the modern alternators are used on cars is because by varying the exciter current the output can remain the same even though the engine speed may be changing over a wide range of speed.
                          • All of the portable generators that I have worked on were exciter type of generators. I don't know of any reason there couldn't be a portable permanent magnet generator but I haven't seen one.
                            low voltage induction motor, how can we find that? Does a car exciter generator work as a motor???
                            thanks,
                            Mario
                            • @Mario
                              Just buy the motor.
                              You can find Compressor motors all over the place. 120vac at 3600 rpm.
                              Use a 240vac gen head which are easy to get as well that requires 1360 - 1600 rpm. 1 or 3 phase.
                              Caps aren't expensive.
                              And a big flywheel.
                              The point is, is you don't need that much to make it work you just the right combination.
                              Personally I am going to the repair shops and searching for Gen Heads. The gas motors go out all the time and thats the expensive part.
                              Also why would you use the remaining phases to run loads. Add capacitance and run the loads from the reactive side like you are the motor. That way the power gets returned to the source and all you have to pay for is the start up.
                              Once the thing is spinning you should not have any trouble keeping it going.
                              Matt
                              • Matt,
                                here's some ideas for the other half. Way more than just one for sale on this link. Different sizes too
                                12KW St Generator Head 1 Phase for Diesel Gas Engine 50 60 Hz | eBay
