Originally posted by vidbid
The Explanation from the Generator i mentioned is from an EE. But seems there is a corn of Truth at it, when Beamgate mentions, its like E.L PMH.
A normal motor has a lot "tooth" at the Rotor and at the Stator. when the Rotor slows down until it stops, it will keep some from this magnetism around the stator locked with the rotor - tooth. And seems this effect is even not teached anymore for EE's, its only explained like, .. its rest magnetism. I was not really sure about, if a pice Iron get magentized inside a Motor or its only temporary. Maybe its both a bit.
But this rest is enough to start again a flow, and as more the generator speeds up as more it energize the rotor again. Thats how it can get full power again.
For the Resonance, i take now the left and right Coil, upper and lower Coil.
As you see at this Circuit above, the left and right Coils are only a Tank circuit with AC caps. Somewhere at the PDF is mentioned, that you have to match them to the upper and lower Coil. So you maybe have to try a bit around to how much Caps you need at last until it runs at best COP.
The Ac caps give a push back into the Coil what will give you the AC at the core. And that is, i assume, the high frequency, what you get on this rotor because of this small values on the caps. Maybe you can slow it down a bit with bigger AC caps. But then you maybe got a problem again to bring them in resonance. To bring a Coil into resonance you dont need to have it from the beginning, the coil come first at a certain Volt and/or certain frequency into resonance. So it doesnt matter, if it runs first inefficient, it only needs the right speed first, and resonance comes from itself. Thats the easier part, when the Coils are right tuned with the Caps.
And at the pdf is also something like that mentioned, that you need first power it up and after its on its speed, you can disconnect it from the powersource.
I got that once with a Coil that at a certain Frequency and Volt it showed a perfect sine wave, even that i did feed it with pulses, what gave me out of resonance only spikes and scratches.
I only dont know at this circuit how it really works, that the upper and lower Coils should run the Motor without tank-caps or something similar where energy is stored. Maybe that Coils still provide enough to run the motor and got enough power for another load until a certain point.
But the setup with this coils aligned alongs is better then as to let them face on a Pole. I made once an Experiment, where i aligned them also alongside and had lesser drag on the rotor but the same energy out from them.
