ACMMJB Device that does not notice it load, Underunity to start with
  • #46
    But while buildin and testing,
    Thugnology is what i build and speak freely
    Ol' Dirty Bastard - Return To The 36 Chambers: The Dirty Version [Full Album] - YouTube
    ( youtube link got nothing to do with building stuff, if ma background music i wanna share when i build stuff )
    Extra old skool while building
    Wu-Tang Forever Full Double CD (1997) - YouTube ( beauty is in the eye of the beholder ) ,
    Peave All, 1 love!
    Greets JB
    Ps Tesla and Oll dirty Inspired
    http://youtube.com/johnnblade
    • #47
      You mentioned in the QandA skype chat that you find it rather odd the way so much hype is being created around the QEG and how it appears hopegirl is making a business out of it instead of true open sourcing. All the CICUs, namings, & what have you. Well, I have my own theory; could it be that they're using this to further their New Age Spirituality agenda, especially a new age view that will be based on new understandings, new "revelation", particularly when it's based on new science, quantum physics in particular, to use quantum physics to prove that God is in every thing and everyone. Not Quantum Physics as a true science of physics, but to use Quantum Physics to take the quantum leap into the so called "spiritual".
      True Christians are not fooled by these religious games because we are children of the truth. If the QEG truly works as an energy device it will succeed separately from the New Age Spirituality agenda and most likely won't even have the word quantum in it's name.
      • #48
        Thnx for responding Bakiri, and i will you in to yr own value as you will leave me into ma own value.
        Explain richard Branson and open source to me?
        Qeg is a win win situation, cause the more peepz work on it, the harder it it is to point the starter of all of this, while they long gone with the money, zippin on some beach, checking this forum and laughing thinking, wow we did good.
        Whitout even showing more ****.
        If i had the power i would unleash 2 peepz,
        TK, and Ufopolitics on yall!!
        Greets JB,
        PS: hows the qeg doing, and the new coil, any new tests yet with the new coils?
        Or to busy chilling on donations money?
        • #49
          Stivep1: Tesla Rehash (Akula device)
          • #50
            Lill update, and boostes my amps out by more then 100 mA
            This is the circuit i used sofare for my tests, concerning freq devider and mosfet driver.
            I found out by diff setups, that the best setup is to have pulses like this.
            . . X X . . Normally i have it like this X X, then i tried . X X
            When i used pulses of X X with 15.40v, 270mA my max amps out was 329mA
            Now i managed to raise the output to 450mA by using . . x x . . Pulses, like that it has some room to pulse back more energy.
            But the most stable is at max 380mA out, cause its like the system has for now in this setup 380mA to spare or 45v ( depends on what i wanna use, amps or voltage ) cause when setting master reset to pin 9 i get 450mA out, but the input goes up by 30mA, so that not good since im used to that nothing changes in my output vs input.
            But for best results ch1 is pin 4, ch2 is pin 7, and reset on pin 5
            . . x x . . Then reset like that, i managed to squize out more amps.
            But there is a but, if i use a pin higher then pin 5 for reset then the remaining amps are being pulled from the main supply, and that is what you dont want.
            Correct me if im wrong, but ima say this, you have can have somuch mA extra, if going over that limit some kind of lenz drag falls in, so adjust reset cycle, and nothing changes again. I must test the whole time when i change a setup to see how the input behaves when i shortcircuit the output, if nothing happens at input, im still good.
            If i want to get up to 450mA i have to use atleast 20mA from input, if i stick to an output of 380mA nothing changes at input, no matter what, even when shortcircuiting the output endor adding 1 ohm resistor.
            So if yr testing and come across this behaviours, you know that you have pushed yr limit for now, unless you add more pickup coils or whatever you use to pick up more.
            Ps: the circuit in the picture is my previous circuit that i started with when going 2 phases. Now its pin 4 and 7. And a few skips to catch the back energy.
            Drop a comment if in not clear on something.
            Thnx for reading!
            Greets JB
            • #51
              ACMMJB Full load test
              Here is a new movie as a reference before i upgrade my device.
              Short circuit on output does not affect the input
              Greets JB
              • #52
                Hi All,
                Cleaned up the circuits, did more tests.
                and broke my personal record of self running, not m,uch but better then nothing when i tried other times.
                the cleaned up circuit works much better.
                i have also done tests with the Kacher circuit by hooking up that to my 1e output.
                Greets JB
