  • hello everyone !
    there's another method we could use effectively, toroidal arrangement can be used effectively as this will lower the frequency from the high voltage power source.
      hello everyone !
      Hi Med. Can you explain what's on your mind ?
      BTW- have you come across the term Unipolar (or mono-polar) impulse?? Actually resonance with much bigger voltage peak as shown on the picture below. Such impulse is created using the (?low?) harmonics of the resonant coil and you tune the duty cycle of your trigger signal generator . I see some advantage as you temporary create MASSIVE potential difference. Like a hammer. Maybe secret of DS??
      I also see you moved to OU.com Do you prefer to comunicate here or there?? I spend lots of time there too
      • Hi John !
        I don't know a lots about the technique you described so maybe there's something interesting there, i am just thinking about another arrangement where we could use toroidal as core but the E-TBC have to be changed to be wound along the core, the problem is the low frequency we have to work with, low frequency mean small output, i guess it's better to work with the mixed E-TBC arrangement, this mean using two toroidal one for the red E-TBC the other for the black E-TBC , the mixed E-TBC is more powerful thousand of time compared the single E-TBC but the problem is the equilibrium, the two side must be loaded in equal , i don't know if this is possible or no, but the mixed E-TBC will operate under no equilibrium state as ordinary single E-TBC, so it can be used without problem.
        the mixed E-TBC is able to attract ambient background power in all direction, magnetic monopole can be created in this device ! since it work inversely compared the single E-TBC where the capacitor can be created by dividing the electricity into two magnetic side, but in the mixed E-TBC the magnetism is divided into two electric side!! huge electric current can be achieved here.. this is just a thoughts
        i started talking about my ideas in OU.com and then moved here, anywhere i found someone interested in this device i give my point of view, just looking for more contribution to this ideas .
        • Hi John, hello everyone ;
          i think i am going to do some experiments once again with the mixed E-TBC, the reason for that is i didn't gave the deserved time for this device, some strange phenomena must be examined once again with better and accurate test conditions, proper grounding have to be implemented better, in my opinion it's the best available choice at this moment ...
          one day i put my multimeter in ampere reading position, the legs wasn't connected to anything but when the mixed E-TBC start oscillating the multimeter read more the 4 ampere even though the legs was open !!! for some strange reason this device is able to push pure current ... the test done when CD connection is open for resonance purpose, CD connection in the mixed E-TBC play the same role as in the single E-TBC but the two devices is far from each other, the idea in the two devices in general is the same, dividing the electricity give the E-TBC or dividing the magnetism to give the mixed E-TBC, this device will oscillate in the same frequency as the single E-TBC as stated before so the structure in the E-TBC is still protected in the mixed E-TBC, what else ?
          in the E-TBC we have to achieve serial resonance in order to gain real useful electric current ( the voltage will be radiant in this particular moment ) but in the mixed E-TBC the electric current is present all the time the same as the voltage, the problem of equilibrium can be solved ... but let's practical test give the answer ! :-)
          • Hi Med. You might make a video
            • Originally posted by John.K1 View Post
              i hope i can do this but i am very busy, in other hand i have to achieve something really work :-)
              • Today one of my family member is dead, he need our prayer ...
                  Condoleance sir...
                  • Originally posted by Wistiti View Post
                    Condoleance sir...
                    thank you so much ...
                    • My condolences med.
                        My condolences med.
                        thanks so much John.
                          just to put a previously posted schematic, because i am planning to work again with the mixed E-TBC as said before :
                          the above circuit is for achieving a high speed spark gap firing, it worked good but the problem is when the toroid inductance put its back EMF in the E-TBC the resulting current will cause problems to the oscillation of E-TBC.. it may even cancel the oscillation.
                          there's a simple solution to this problem to let the above circuit work very well !! i will let you think about it, so later we could talk !
                          • hello again !
                            the above circuit will work just fine if the E-TBC is connected through CD ! not AB as discussed in the past, if connected thorough AB the 5nf capacitor will oscillate with the inductive side of E-TBC, this is the first problem, the second problem is the back EMF current injection through AB will cause a magnetic field... in most case will perturb the oscillation of E-TBC since it's able to create an induced rotating electric field inside the E-TBC ..
                            if we feed the E-TBC through CD there will be no inductive side, so the 5nf capacitor isn't able to oscillate with the E-TBC, the current injection isn't able also to create a magnetic field inside the E-TBC because it's a simple junction without any induction or at least very small to cause any problem!
                            the benefit of the above circuit is to cause a good conductivity when the E-TBC in oscillation mode without causing any problem, it's just for ionizing the air
                            • just to add something , i am planning to use the above information on the mixed E-TBC, more info will be posted soon, when i checked some previous setup on the mixed E-TBC i found L2 coil wound on the same direction - as you know we need two coils in L2 side one ccw but the other is cw -- it's a big error....
                              the equilibrium in the mixed E-TBC can be achieved by just adding two coil wound reversely CCW plus CW the end of these coil have to be connected together so the same polarity will be achieved ! the magnetic field direction must be directed to the same axis .. more info will be posted as soon as possible GOOD NIGHT FRIENDS
                              • Hi John! Hello everyone ,
                                i am just trying to make an instructional video about the discussed ideas on this thread, my English isn't so good
