Sweet
Thanks everyone! I will be using a variant of Ken's idea with some aluminum angle I have. I know, I know, eddy currents. Not perfect but maybe good enough. I do not have plastics or the machining tools for plastic/metal, only wood working tools. And lots of glue
. I want to be able to adjust the angle 30-45 degrees as suggested. This will skew the center line unless I get things exact. As Mack said, easy to fail.
Ufo's post #167 above is dead-nuts-on. Easy to test yourself. I did. I still think we will have to further scrutinize the interaction between the ramp being induced by a north rotor and the south stator. This is probably where shunts will be required.
Thanks Again,
Randy
. I want to be able to adjust the angle 30-45 degrees as suggested. This will skew the center line unless I get things exact. As Mack said, easy to fail.Ufo's post #167 above is dead-nuts-on. Easy to test yourself. I did. I still think we will have to further scrutinize the interaction between the ramp being induced by a north rotor and the south stator. This is probably where shunts will be required.
Thanks Again,
Randy
when it comes to bonding
