Magnet motor revelation
  • any progress
    Originally posted by Mario View Post
    Hi all,
    attached just a rough hand drawing. Not included is the distance between a stator magnet and the next ramp, (in case of more than 2 setups around the motor), which should be equal to 1.5 - 2 times the distance between rotor magnet and ramp at the widest point.
    I have not added the bent down part of the ramp as I'm having a hard time getting Madmacks last part. The induced poles are clear but some sentences I'm struggling with.
    If you move (slide) a magnet over an iron bar with a spacer in between the only forces I see are:
    -attraction towards the bar as the magnet approaches it
    -constant force as you slide along
    -magnet attracted back as it wants to leave the bar
    I can't see any force that wants to hold the magnet in the middle…
    Mario
    Hey Mario,
    I'm re-reading from post #1 and trying to understand what I missed on ramp building. Noticed the picture you posted which looks similar to J. Bedini all repulsion motor that Turion posted earlier. Did you get it to spin or accelerate past the stator magnet with out tapping it past?
    Wantomake
    • It's brainstorming type weather for putting together a MadMack
      magnet motor. I will do a video also on how my rotor failed over
      a measly micro smidgen got those magnets glued in good
      enough to last me a lifetime and now I'll have to take a hammer
      to them
      Nothing takes the place
      of a picture. It's worth a thousand words they tell me.
      • Here is my complimentary video for step one in the
        MadMack Magnet Motor design. For those of you just chiming in
        wondering why people are still trying to make magnets a free energy
        source let me say that magnets have always been that.
        MadMack does not do video, therefore show and tell is an undertaking
        of those who replicate verbalized instruction. MadMack spent 40 years
        in the industrial engineering field and I am sure acquired
        many expertise in that time.
        During the course of years MadMack had studied patent documents
        and in time built his first Magnet Motor of which he developed into more
        advanced designs later on.
        The video you see of me is what I have "Gleaned" from MadMack
        and since I have always wanted to build a magnet motor Macks
        information caught my eye right away.
        Step one is (CENCELLATION) Also I am showing pieces of my build.
        In step one 2 rotor magnets are faced off with 2 stationary magnets
        called stator magnets. You will see.
        [VIDEO]https://www.youtube.com/watch?v=dQn9koeshws&feature=autoshare[/VIDEO]
        • Madmack,
          Hoping that all is ok after your surgery.
          To All,
          I've not had a chance to work on this project lately, hope progress has been made by someone out there.
          Been reading and studying the Magnetism book and postings from Madmack to get better grasp of the ramp build.
          wantomake
          • has anybody heard from Mack ?
            How's he doing after his surgery ?
            thx
            Chet
            BE that change !!
            • Well I use to work at the hospitals and I can tell you sometimes the
              patient is tested just before going in and a delay of a few days before
              could be set so everything goes smoothly.
              He may have just gotten home after a long wait, well I mean he doesn't
              have to keep running back so much. I don't know about Mack but we
              better let him rest for several weeks more. At our age getting cut don't
              heal up at fast as it use to.
              @Don't worry about anything Mack, my bearings are almost here
              and my rotor got a pilot hole and circle in it last night. I have some
              other materials on the way so when I can in the next few weeks I'll
              be back to show everyone.
              I heard UFO is working at multiple cells.
              I have some brass inserts that are barbed and I have a $3000 ultrasonic
              probe on like a drill press stand along side a giant heavy duty power
              head to pump out the waves. These things work beautiful.
              I am sure you know what i am talking about, you drill a hole alittle smaller
              than the insert, much like you do when you drill and then tap a thread, put
              you part over the hole in the acrylic and gently apply pressure.
              This might be kind of nice so I can tighten things down without having
              nuts sticking out the bottom plus the threads on these inserts equal
              having say 4 nuts worth of threads so lock tight works great.
              I know it is not that important for proof of concept.
              There is something about drilling many holes in plastic that are better
              filled in with an insert so maybe the plastic won't get weakened so
              badly. My 1950 trim saw machining table makes nice cuts too.
              Also I am still dreaming up ways to produce my first adjustable rotor
              magnet mount and when I do you can count on me to show everyone.
              I have an oven I heat plastic in sometimes so for the base I think I am
              going to melt down some scrap HDPE I have into a 1.5" thick sheet
              18" X 18" and man does that stink for a few minutes. I always melt my
              plastic outside and in less than 30 minutes the part is on the cool down
              phase.
              I use a heavy steel plate bottom so it comes out super flat using sides
              much like a concrete form looks only I just fill it to the top and let it cool.
              I also need more time to measure magnets to see if this pile I bought
              has 2 rotor magnets about the same, then another 2 magnets for
              the next place around the circle. It seems like to me as long as the
              sets are close to one another it will have fewer anomalies.
              Once my rotor bearing and rotor are cut I am going to a happy man
              since I won't have a floppy rotor like before. I was noticing just
              how strong these 1/2" square magnets are and thinking how important
              it is to have a good solid bearing to work with.
              I don't know for sure if I am going to like the bearings yet til I try them
              out. I will be better than the last set. Then there is the cuts to make
              for the rotor mounts as they need to be identical to insure balance.
              I have a million questions for you that will have to wait til I dig my way
              out of all of this work that needs to be done first. By then it might be
              somewhere between "TURKEY DAY" and "XMAS"
              Hope you are well and feel up to hanging out on the thread say in about
              a month, maybe less. Either way we have a lot to go on
              that we received first hand from you that will keep us going for awhile.
              Cristian is almost there.
              Til then Macktake care of yourself and may THE KING OF GLORY
              shine on you in HIS great kindness.
              • Hey Mack
                I been looking at bigger magnets again, like 1" at K&J Magnetics
                and they sent me this warning video. Still waitin on bearings
                and will be cutting my rotor that I got on it's own hub now.
                [VIDEO]https://www.youtube.com/watch?v=0t8yDnyOaQ8[/VIDEO]
                • Hello Everyone
                  I got my bearings to day MACK. I should cut the rotor in tonight.
                  It really floats freely and nice, I love it. The rotor is 3/4" acrylic.
                  The bearings come empty and zerk fitting come with it. I like
                  the magic oils better. The rotor is rock solid, but I'll need more time Mack
                  2 weeks plus with these days ahead. You know what I mean
                  I'll BRB to show the nuts and bolts later.
                  You guys are awesome.
                  Good video's Cristian.
                  • Hi MACK and the Gang
                    Thanks Cristian, the washer is 304 stainless steel
                    Check this out guys, this is really really free and easy.
                    [VIDEO]https://www.youtube.com/watch?v=W9DL9g1z3t0&feature=youtu.be[/VIDEO]
                    • Hi Mack, hope you are on the mend.
                      Hello to all, i finally had some time to make a rotor, am in the middle of my first Garlic harvest on the new farm, so time is scarce.
                      The rotor disc is form ply, which is cheap and reasonably stable, i will be starting with the magnets in line with axle, to alter the rotor magnet angle i will simply cut slots in the ply to desired angle and use the same magnet carriers, as the carriers are the hardest to make.
                      Now to make two stator magnet holders that are adjustable, in and out, and for angle.
                      Best Regards, Cornboy.
                      • Nice going Cornboy
                        I like to pick up ideas such as yours for the rotor magnets to
                        move.
                        This is what I did for a few minutes today. I got out my grinding table
                        It uses a standard grinder that is C-clamped to the table and the 2
                        bearings as well.
                        It really makes a nice edge if folks don't have their lathe yet. My
                        perfect circle is still here, it is 15" by 1" thick set up to do magnet
                        tests.
                        • Comment
                          • Thanks for the kind words guy's.
                            @ Wantomake, i will use the same magnet holders, and just machine more slots to fit them in, at the desired angles.
                            The rotor holders will have a small amount of adjustment to balance out the forces.
                            I have made some very chunky, solid, stator holders that are fully adjustable, and will be trying small gaps between magnets, which requires a very strong embodiment.
                            Regards Cornboy.
                            • Excellent work Gents, keep stirring the pot so to speak.
                              • hope all is well
                                Mack
                                please send out a word on your health and well being.
                                in the mean time here is a man playing with tapers and attraction in a very
                                simple perhaps similar way ??.
                                youtube magnet rolling on narrow triangle metal a simple magnet ramp - Bing video
                                I found this originally here At Mark Dansie's site
                                Bill Gates, Mark Zuckerberg to form multi-billion-dollar clean energy fund - Revolution-Green
                                respectfully
                                Chet K
                                BE that change !!
