Originally posted by Turion
So you have four identical magnets and you think this is the
problem?
From here is harder to explain one's self andtougher to ask questions. It is good for YOU to be a skeptic because
of your special gentle traits. Everyone must do what is needed in life
to keep balance. We all learn the best way to proceed as we gain
experience.
The attraction side VS repulsion should not be causing one side to
be non functional. I say non-functional because the side that does
not give the effective response we are looking for. I just got a larger
set of magnets tonight that is not the set I just got in the mail.
Still no hole in these either. I have a ton of magnets that are slightly
arc shaped for the large pancake motors. I have 4 that stack one
on top of the other and are a matched set as far as I can tell.
Now one thing rolling around in the noodle.
The discussionwe have been having about balancing magnets is as follows.
This is for me.
1. Move magnets or adjust magnets on some sort of adjustment
thread. (Well I see you did that) Still it is out?
2. put more or less iron on the backside of the stator magnets to
even up the small differences.
Do you understand that idea? I picture this like putting a tiny set
of thin washers all around the back of a magnet to make it stronger.
But only a tiny bit stronger.
This is all I have so far on the subject of "tuning a magnet"
Using this idea will keep us from searching high and low for perfectly
equal in strength magnets. I think this should be done.
Which ever magnet you think is weaker add a tiny bit of iron to the
backside for tuning.
Nice work Dave, you beat us all to the draw.
