Motor Generators
  • John Bedini sold the Tesla Switch kits consisting of relayed energy thru mini converters. A motor gets the energy from a series of batteries that keep themselves charged
    • here is a person who has a Tesla switch and a full set of vocal cords. this guy is not ashamed of his work but I guess everyone else is
        https://www.kjmagnetics.com/calculat...calcType=block
        PS: I haven't found anywhere else yet, a similar methodology for calculating the resulting ampere force
        Click image for larger version  Name:	00002222.jpg Views:	0 Size:	208.9 KB ID:	508356
        Like this?
        https://www.calctool.org/CALC/phys/e...ism/ampere_law
        • bifilar tesla charging of large battery pack. self charging
          • history lesson of Tom B. MEG
            Originally posted by Lunkster View Post
            Motionless Switching Magnetosphere Electric Generator
            This Generator is designed in the shape of the Magnetosphere.
            The core of the generator has a common switching coil(electromagnet) with
            two large permanent magnets on each side of the coil. There are fins
            around this core. There will be several fins around the core so that
            the assembly will look like a sphere. The fins have permanent magnets
            spaced out in the fin in such a way to move flux from one magnet to the
            next magnet in the fin and then through the core finally flowing
            through the fin again. One the outside of the permanent magnets in the
            fins are coils. The coils are spaced farther from the permanent magnets
            so that the normal flux flow moves from one permanent magnet to another
            producing one large ring of flux flow using the core as part of that route.
            The magnets and coil in the core are larger that the fin magnets so that the
            core can handle the travel of the sum of flux flow from all of the fins in
            the generator.
            This generator design is different than the Sphere Generator I have already
            designed because it uses permanent magnets in the core rather than
            core material. I believe the permanent magnets will provide better
            assurance that the large ring magnet function will work. At least it should
            work better than core material. Also, there is only one coil per permanent
            magnet in each fin rather than more coils in the sphere generator. The
            reasons for this change are that having one coil outside the permanent
            magnet means it is farther away from the core, this will reduce negative
            interaction between the fin coils and the core magnets. This design
            will also allow more fins to be placed into the generator. More fins
            means more power generation. The coils in the fin need to be large
            enough to handle the flux that will be moving through the coils.
            The operation of the generator is about the same as the sphere generator
            I have already designed. This new design will operate with more power
            and efficiency.
            The way this generator operates is that each fin assembly works in conjunction
            With the common core assembly. The normal flux flow is of each fin is through
            the core creating a large ring magnet. So, the generator will have several large
            ring magnet actions being performed at the same time.
            There is one large coil that has a core that supports all of the flux flowing
            Through its core when the power is off to the generator. Once the power
            Is turned on to the coil, the coil produces a magnetic field that opposes
            The direction of flux flow through the core. What this does is it breaks
            The large flux ring flow of the flux for each of the fins. The flux then
            Looks and fins the next easiest route for the flux to flow. Most of the
            permanent magnets in the ring will then start to use the core in the coil
            that is closest to it in the fin assembly to travel through to get to the
            other side of the permanent magnet. The reason it takes this route is
            because the core material is an easier path than an all-air path to get to
            that side.
            The electric power generation is performed through the coils that are
            Beside the permanent magnets in the fin assemblies. The is wire wrapped
            around the coils cores that will have electricity flowing through them
            as a result, change in flux movement. In fact, there is flux either starting to
            flow through the coils or reducing their flux flow with each change in the
            electrical condition on the one electromagnet at the center of the generator
            core. With the best switching speed for the generator, it means that the
            electromagnet can operate at a 50% duty cycle while each coil in the generator
            can collect alternating current 100% of the time. So, the generator uses one switching
            electromagnet operating at a 50% duty cycle to be able to collect electrical
            energy from several coils at the same time.
            The electrical energy to produce a magnetic field for a 50% duty cycle in this
            Generator should be a lot smaller than the several coils producing electrical
            Energy from the several permanent magnets that are changing their flux
            Routes. This is similar to a FET or transistor where a larger amount of energy
            is being controlled by a smaller one.
            Please build one of these, you will be glad you did.
            I have written three books on unique generator and motor designs along with several applications for them.
            It has come to mind that the best invention would be a generator that does not need outside energy to operate it.
            This generator design utilizes the internal power that is already in permanent magnets.
            This is my best design so far.
            Click image for larger version  Name:	Drawing zzz.jpg Views:	106 Size:	189.1 KB ID:	508294
            Once you have free electrical energy production, then the efficient motor designs I have are not as valuable because you can still
            use the current ones. But if you want an electric car that never needs to be plugged in, then I would still pursue
            the motor designs in my books sold through kindle direct publishing.
            Lunkster
            • Comment
              • energy generator machine
                • Sav went public with their Motionless Generator in 2015
                  • motor generator, built in dual flywheels
                    • Collecting bench work data first
                      • Get your head blown off
                        • magnet power, while it runs you can not see the rotor
                          • Comment
                            • Comment
                              • Comment
