MickeyMouse, I did answer the question. You simply just don't want to see it. Maybe you should re-read my answer. Work performed is worked performed. Positive, negative or whatever else Thane wants to call it doesn't matter. You perform work and that requires energy.
Thane has a problem accounting for where the energy comes from. He thinks it comes out of nowhere which isn't the case. He only looks at kinetic energy of his rotor and forgets to look at what comes from the prime mover. It's like saying I have a disc of mass m spinning at speed v. Now I double the mass but the disc still spins at speed v and then saying that both cases required the same amount of prime mover energy as they both spin at speed v.
At this point, all I can say is that BroMikey = Thanes = 2x MickeyMouse. Maybe should should try and solve that set of equations first.. The solution is very simple, but why don't you write it down for all of us and tell us what variable BroMikey is and what variable Thanes is based on the above set of equations. So at least I can confirm if you even know how to solve equations.
If you can provide the correct answer, I will give you back some credit, but at this point you have lost all
under full load and a light loaded condition you will get maybe 85% and the ultra-light load a small portion higher. The problem is in the real world, not this fantasy land you heckle in, generators loaded to 3/4 gives a 70%.
