Again, why do it?
So you have your generator running at 1800 RPM steady at rated load on the coil. The power to turn the rotor at 1800 RPM at that load is the same whether the coil is multi-filar or single-filar when the wire size and number of turns are the same. What else needs to be said?
But you did say it here,
I'm not saying you're correct, but if you believe what you wrote, why do you continue to promote "speed-up under load"? Isn't the design objective to produce more, not less?
I never said winding the coil a certain way will not cause the rotor to speed up when the coil is shorted, or loaded, compared to no-load. All I've said all along is that the phenomena is irrelevant to generator performance at load. Which has been verified by the only A vs B test I've seen (the subject video) where the A vs B test was conducted fairly. All you present is conjecture, no direct evidence (tests at load, A vs B).
I don't care. Waste your time with it. But please, don't try to convince me that it in any way substantiates your (2kw out)/(300w in) claim.
Originally Posted by Turion View Post
2. The MORE you speed up under load the LESS your coil produces as a generator coil so the perfect coil does not speed up or slow down.
