Anti-gravity
  • Al
    • Totally irrelevant and meaningless posts, as usual.
      What else is new?
      VIDBID
      • Scientific Method
        [VIDEO]https://www.youtube.com/watch?v=N6IAzlugWw0[/VIDEO]
        Code:
        The scientific method - YouTube
        VIDBID
        • Gravity is not a force according to Einstein
          [VIDEO]https://www.youtube.com/watch?v=lZdm239wH64[/VIDEO]
          Code:
          Just ask a baller for a citation that gravity is a force... - YouTube
          Please provide a citation which states gravity is not a force.
          Is gravity a force?
          No.
          Gravity isn't a force, according to Einstein.
          VIDBID
          • Einstein assumed that IF the speed of light is a constant, THEN e=mc2
            after that, others took this to mean that there was some absolute that e=mc2
            now the equation itself is not often talked about,
            but it seems to assumes some sort of angular momentum of matter.
            it is a good idea, but sure not one so foreign that no one else would have come up with it by now.
            so,
            I ask,
            if Einstein thought that gravity was not a force,
            did he have all the data ?
            what makes him so special that his assumptions turn to fact so fast ?
            • Originally posted by aljhoa View Post
              And there is no atmosphere under a dome.
              An atmosphere (from Ancient Greek ἀτμός (atmos), meaning 'vapour',
              and σφαῖρα (sphaira), meaning 'ball' or 'sphere'[1][2]) is a layer or a set of layers of gases surrounding a planet or
              other material body, that is held in place by the gravity of that body.
              Therefore, a 30 mi long pipe, capped at the bottom in the atmosphere, holds 14.7 lbs of air and its wall has the "side load cross section" that of Figure B.
              A 30 mi long open pipe holds no pressure.
              A dome above flat earth can be pressurized but it will not surround a "disk".
              Only Earth has atmosphere, whereas a flat earth under a dome has atmo-simous pressure (acting in all directions).
              Al
                Al
                Don't make assumptions without some sort of evidence to point you in the right direction.
                Is it not enough to know that no one has yet provided any evidence of gas pressure existing without the necessary antecedent of a container for the gas to press upon?
                Why do you have to try to understand the shape of that container?
                Why?
                So, can you employ the scientific method to determine the shape of something?
                Natural phenomenon observed: AIR PRESSURE
                In order to have gas pressure, the necessary antecedent of a container is required for the gas pressure to press on.
                So, you need a container, do you?
                What does the container hold?
                Air pressure.
                In the case of the Earth, is that all the container holds?
                No, it holds other things.
                Like what?
                Land, mountains, lakes, seabed, seas, oceans, etc.
                Do we have maps of the Earth that truly define area accurately?
                What does the military use?
                The need accurate maps for artillery, do they not?
                How do they measure the distance from point A to point B on the Earth?
                They don't want their projectiles missing their intended targets, do they?
                What kind of map does the military use?
                [VIDEO]https://www.youtube.com/watch?v=cVpF_5UTPFE[/VIDEO]
                Code:
                VIDBID
                • Originally posted by spacecase0 View Post
                  so,
                  I ask,
                  I'm not an Einsteinian, but I like to throw Einstein in the mix when someone starts spouting that gravity is a force.
                  My understanding is relative density disequilibrium causes differential force to be applied to an object until relative density equilibrium is achieved.
                  VIDBID
                    Why?
                    Air pressure.
                    VIDBID
                    A square inch vertical pipe, 100 meters long, capped at the bottom end, and filled with a fluid,
                    has pressure of about 10 atmospheres (not 10 atmo-simous or 10 atmo-disk pressures),
                    why this fluid does not come out?
                    Al
                      VIDBID
                      Al
                      What?
                      What are you talking about?
                      Can you demonstrate this?
                      Can you show me this?
                      What do you mean by a
                      "square inch vertical pipe"?
                      What does that mean?
                      "A square inch vertical pipe, 100 meters long"
                      Why are you combining imperial measurements with metric measurements?
                      filled with a fluid, has pressure of about 10 atmospheres
                      "and filled with a fluid, has pressure of about 10 atmospheres"
                      I'm not sure if you're referring to the pressure of the liquid or the pressure of the gas.
                      Aren't Standard Atmospheres (ATM) used for air pressure?
                      What you're attempting to illustrate isn't very clear to me.
                      Why does the fluid come out of what?
                      I'm not sure what you're asking.
                      Didn't you say
                      You said the vertical pipe is "capped at the bottom," did you not?
                      What is the point of your question?
                      What are you trying to ask?
                      I'm not understanding what you're trying to ask.
                      Let's go to something simpler.
                      Here's an image of a glass half full of water.
                      What is your question?
                      VIDBID
                      • [VIDEO]https://www.youtube.com/watch?v=-ZNqwdzjos4[/VIDEO]
                        BALLBUSTERS 17 *LIVE* - YouTube
                        Code:
                        Only works on a flat plain.
                        VIDBID
                          ALL Earth's fluids into UHV Sky ,
                          Al
                          • [VIDEO]https://www.youtube.com/watch?v=-RzqiDmRAeA[/VIDEO]
                            FED Toe Tag 823 - Toady - YouTube
                            Code:
                            See what happens when dealing with "people" who don't understand the scientific method..
                            VIDBID
                            • Absence of evidence is not evidence of absence.
                              If you can't see a barrier, does that mean that it isn't there?
                              Did you take the above picture yourself.
                              No, of course, you didn't.
                              1. Begging the question fallacy
                              2. Reification fallacy
                              3. Affirming the consequent fallacy
                              The image is phony.
                              It's photoshopped.
                              [VIDEO]https://www.youtube.com/watch?v=bQSoRMrCRzk[/VIDEO]
                              Code:
                              "It is photoshopped, but it's, it's has to be." Robert Simmon AKA 'Mr. Blue Marble
                              You still can't have air pressure next to vacuum without a barrier separating the two.*
                              The atmosphere at around 110k Ft is over 5 billion times as dense as ultra high vacuum.
                              Gases have three characteristic properties: (1) they are easy to compress, (2) they expand to fill their containers**
                              To believe otherwise is to be deluded.
                              *Boyle's Law, Second Law of Thermodynamics
                              **Source: https://chemed.chem.purdue.edu/gench...properties.php
                              VIDBID
                              • [VIDEO]https://www.youtube.com/watch?v=vRATS7syrWg[/VIDEO]
                                Flat Earth Debate 894 Uncut & After Show - YouTube
                                Code:
                                VIDBID
