Smallest Gap, any way you can..!
[QUOTE=Jetijs;8557]Thank's Peter
I will redesign the rotor to the X form and make the air gap thinner. But I think, that I won't be able to make the air gap thiner than maybe 0.5mm, because the tolerance of the laser cutting machine is only 0,15mm. Also the shaft an bearing system must the be very accurate. Or maybe I should cut the X rotor a little bit larger for the startor to fit in and then just machine off the needed thickness with lathe, that way the tolerance of the laser is no longer crucial and I can make the gap even smaller
I think, my X type rotor could be about 120mm in diameter so I don't need to redesign the stator core.
Dear Jetijs,
Yes, the new design will work well for you. Your idea of cutting the rotor pieces a little over-sized, and then machining them back on a lathe is the right way to think about it. If the rotor pieces are made of standard motor lamination material, they are very difficult to machine. You will need the hardest ceramic cutting tools in the lathe that you can find. Also, its an "interrupted cut" so the stresses on your rotor can be pretty high. Just take very small cuts, like .001" or less at a time. If you can do this, you should be able to practice a .1mm gap on both sides for a total gap of .2mm. (Also, don't forget, when you take a .001" cut on a lathe, you are taking .001" off the RADIUS, which is actually .002" off the DIAMETER of your material.)
When you get to designing the circuit part, post that here to so I can help you with that as well.
I'm committed to your success. Every mistake we can catch BEFORE you spend any money is cheaper to fix!
Peter
I think, my X type rotor could be about 120mm in diameter so I don't need to redesign the stator core. Thanks,
Dear Jetijs,
Peter
I have come up with such a design:
