You know , Earth magnetic field is not flat, there are field lines going N-S or E-W or from surface straight up ... I'm sure that absolutely ALL OU devices just tap Earth magnetic field somehow. I hope someday you will see that too.
Read for example patent 160 152 by J.C.Bryan from 1875
I had second one but now it's lost. All mentioned N-S orientation to tap magnetic currents in the earth.
Consider also different inventions so far from earth battery which supposedly tap the same energy.Like Hubbard coil, Lester Hendershot motor or some closer in time to Stubblefield like Roy Meyers Absorber from 1913
The funny thing is that we are tapping Earth magnetic field indirectly in all induction generators and motors.So called stall effect or unknown effects of starting motors different energy required when cold started or re-started again after a small period of rest.Almost 200 years of tapping that energy.
What is permanent magnets are not what we are thinking about but just a lens for Earth magnetic field ? Crazy idea, huh ?
How do you think testatika is working ?
. I'd settle for 300 mA, but mine is no where close to this either. Looks like it is in the 320uA range. On thinking about this, however, J Bedini says that you can't measure radiant energy with normal meters. Perhaps a gauss meter would be more useful to see what is happening with the coil?
