Imhotep's Radiant Oscillator Video
  • Yes i am Australian. I would imagine the accent gives it away!
    • " What ever it is I love it!"
      Originally posted by Bodkins View Post
      YouTube - YouTube - Bodkins 9 BEDINI IMHOTEP TESLA
      whatever its is i love it!
      Carmine Quote
      Bodkins looks to me u should be seeing this too... your fan... might not be as good as a Bedini set up.
      The fan is a bedini setup and just switching tool.Thats all the original imhotep relay was!
      Bodkins, Nat, Byjove, Carmine, and Von---
      I agree with Bodkins--whatever it is that we are seeing--I love it. I am going to run my Pie Pan experiment again to look for more answers. Von-- you are right about the rf because that is why I can hear it on my little tuning radio. Carmine and Bodkins you are right about there being HV all over the place (I quit counting how many times that I got shocked). My HV finding came off my Bedini Fan circuit however and the pie pan experiment using the closed up Lunch Box didn't result in shocks outside the box. If I touched any part of the Pie Pan circuit---there was no shock. Even where I was getting those over 100 volt readings. The Pie Pan circuit is insulated from the CFL circuit in my last experiment. I want to somehow put them together.
      Nat --I may try some sort of sphere antenna to see if I get any different readings. Like you, I have been doing alot of research on Tesla. I maybe getting a simple transformer induction result in my particular experiment instead of the static electricity charge like what the Tesla ball receiver gets. Then again this may be a hugh tangled up mess of all kinds of energy. Bedini says that an SSG has energy all around it like that. I think that is why he recommends that all the parts be very close together.
      Cheers,
      Lidmotor
      • Originally posted by nat1971a View Post
        Two-rite mayt..!!!
        Ya karnt pull the kangaroo-skin over uz old 'Pommies' eyes Bruce!
        Thats coz weer two shaaarp, ya see?
        B'sides...
        the upside-down image reeelly gave it away, oh and the 'canny; stains all over it, of course...
        G'day mayt
        "I say that if a TEN year old can do this and win, what the **** is wrong with the whole World?"
        ~ John Bedini ~ 8 Mar 2000 - http://www.keelynet.com/bedmot/bedmot.htm
        • GDAY!
          @Lidmotor
          Without a doubt the sphere is the way to go as it will induce pressure evenly over its surface.
          The big question is how big does it need to be.
            GDAY!
            @Lidmotor
            And what to do with the recovered energy.
            Charging a 3rd battery is the only way i see us holding on to the potential we have in our hands.
            Im hoping i can get a little imhotep fan running off the cap to charge the 3rd Battery.
            Anyone for Cake!
            • Lidmotor,
              I like were this thread is now going.
              This may turn out to be your desert box.
              Would be interesting to see if a sphere would contain the energy.
              You may also want to look very closely at Roy Meyers Absorber Patent to see if something may suddenly dawn on you. I attached images. He understood this loose or radiant energy as needing to be aligned to magnetic north, which is obviously just utilzing the earth's EMF spin to produce current utilizing this scattered energy, loose cannon. Zinc bars, magnets, and iron wire are used in what appears to be an "Absorber" or "Concentrator". The iron wire obviously gives you this long magnetic flux field. The zinc has strong electronegativity, sucks/draws the energy into the circuit. He coils the iron wire around the magnets which then becomes the hot wire, output, and there's your "cell". I get lost there, to connect/apply your energy to it, but the second image, the v-shaped zinc, seems to be the way to go, maybe all aligned to magnetic north.
              The main point here would be that he found ways to align/tweak/concentrate the energy (75amps).
              Roy J. Meyers: Absorber (Atmospheric Electrical Generator)
              Better Images Here: Chapter7.pdf
              SM
              • Hi Lidmotor,
                You guys all are doing tremendous research, well done. Manyany people who are into listening to Shortwave Radio use a Slinky as an antenna to improve reception. I don't know if would be possible for you to get your hands on one as an experiment and play around with it. The antenna picks up frequencies in the upside of 7 Mhz, is there anything in that range with the experiment your working, or would it be different that the aluminum pie plate... on I dunno but it would cost $3.00 or so to find out
                Here's a link for a bit more info Slinky
                Good Luck and keep up the great work everyone !!
                Will
                • Lidmotor "Blue Plate Special"
                  Thanks guys for all the tips. Now I got a problem. I have the little energy "bugs" trapped in a capacitor but every time I open the jar they fly away. There is a bunch of em (volts) but they are little tiny buggers (no amps).
                  Today I cut the bottom out of the pie tin , insulated it, and stuck it right inside the Lunch Box. I then stepped back and turned the sucker on and waited for a big smoky explosion. Nothing happen except a ton of volts came flying out. I grabbed a big cap and caught em but now what? They refuse to go into anything else.
                  Nat, I tried a hollow tin foil ball before I put the plate in the box and also several different coils of wire. Nothing worked as good as that aluminum pie tin. My antenna arrangement is just picking up "local energy" off the box circuit. Bodkins when I got done with the experiment and I was putting things away I noticed that I could make the 2 CFL lights come on by touching them. They were both turned off. They would not stay on if I let go but it was still strange to see it.
                  Here is the "Blue Plate Special" video
                  YouTube - Lidmotor "Blue Plate Special"
                  Lidmotor
                  • @lidmotor
                    I haven't had a lot of time for experimenting as of late. I am in the middle of testing out different caps...I tried 8000uf and that charged way too slow and i tried a 470uf cap and that seemed ok. So i guess somewhere in b/w is the sweet spot for my circuit. Whether this applies for your circuit who knows. There is only one way to find out.
                    My insulated plates are much bigger than what your are using too. And they are approximately 10 feet in the air on the roof of the garage. The height and size of the plates plays are part in all this.
                    I have also switched to a ground aluminum plate as per what Tesla shows in the patent. That seems to work a little better too.
                    • @Nat
                      Quote
                      Aluminum in the GROUND Nat?
                      Uploading video Connect the fluorescent tube to trigger then Ground of the scope.
                      • @lidmotor
                        just a thought...try your original pie tin upside down.....just curious to see if there is difference or not as that would sort of look like wardencliff tower
                        • lights connects to negative on the scope not coil at 1 minute 30 i say coil i mean scope!
                          YouTube - Bodkins 10 BEDINI IMHOTEP TESLA
                          • Shapes & Flows
                            • Originally posted by DavidE View Post
                              Tesla French Kiss
                              • I made this post at OU.com (The Tesla project)a while ago and thought it might help explain the nature of the energy you are dealing with.
                                @All
                                I think there are many people here who have built and experimented with tesla's Patent 568177 and most if not all have been left with one single question-----Why? What is the purpose? They might say "I have currents of high potential and frequence now what?". My understanding came only after I understood the nature of what I was dealing with, that is what qualities does this current have in relation to other currents. I think I outlined the qualities well enough in my last post and I think we should be familiar with Tesla's ozone patent so we will take the next step ---- utilization of the currents in the secondaries.
                                To take the next step we need to put aside EM induction and concentrate on Electrostatic Induction. Here is a good link to the general process-----http://en.wikipedia.org/wiki/Electrostatic_induction . At this link there is a picture of an electroscope which I have posted here, a (+) charged wand is brought near the electroscope charging the upper conductor ( - )negative. Next a potential difference(charge seperation) occurs in the electroscope conductor, if the (+) foil leaves inside the electroscope are grounded then the electroscope conductor could be said to have a "net" negative charge, making the wand and electroscope a capacitor. I see this a little different, the (+) charged wand produces a ( - )negative field around itself as all forces must balance, the electroscope enters the negative field and is charged negatively producing the charge seperation.
                                In the circuit below (lower right) we have Tesla's Patent 568177, the secondaries L2 have high potential/high frequency currents alternating, that is one end of the secondaries will be charged positive then negative and back to positive repeatedly at a high frequency and high potential. In the one instance shown, one end of the secondaries L2 is positive, I see this positive end as expanded electrons. The capacitor C2 is connected to the positive secondary L2, the diode only allows potential to flow in one direction so the positive plate of C2 will never be charged negative. I am using electron flow notation (negative flows to positive) so all of this may seem confusing, think of negative as tightly packed electrons(compressed) and positive as loosely packed electrons(expanded)---- each flows to the other equally. Now think of the electroscope, the positive plate of C2 is the wand and the negative plate of C2 is the top of the electroscope. In order for the forces to balance in C2 electrons must flow through ground through the battery (B2) charging it and into the negative plate of C2, the battery (B2)charges because its potential is 12 volts and the potential at C2 is thousands of volts. If there was no ground you would only have a charge seperation in the circuit but you would not have a "net" charge on the negative plate of C2, just like in the electroscope example. We should understand that the only current flow is from ground to the negative plate of C2, the positive plate of C2 has no current it has a "static" charge not unlike a statically charged balloon might have. When the capacitor C2 has equalized its charge on both plates the DPDT relay switches over and the high potential on C2 charges the battery (B2) again . L2 must then recharge the positive plate of C2 with potential. The battery has been charged twice and all you have done is charge one plate of a capacitor on C2. You may have figured out that there could be many capacitors at the position where capacitor C2 is as well the circuit outlined by the red box could be replicated many times over on one end of the secondary L2. The secondary L2 also has two ends , each having a changing potential as such both ends can be utilized. I believe this process is what many inventors have refered to as using potential only, no current as current will only discharge the source of the potential. There is also an issue of electrical inertia in the battery (B2) which must be considered in the timing of this circuit, but things get a little complicated so there is no need to confuse the issue at this point. This is the only explanation I have for what I have seen in my circuits, the battery B2 charges and is equalized periodically with the other battery B1 and both charge.
                                AC
