Originally posted by wrtner
Here you can found good info about the VAPORIC FORCE that I call HYDROGEN BOND ENERGY ..
SVPwiki : Keelys Vaporic Force
I have extracted this:
In the first chamber of the generator is air, and all that is necessary to get the first start is to stimulate this air by vibrations and thus create a small disturbance. Water dropped into it will do that.
When the air gets into a second chamber it comes in contact with the vibratory ether which acts upon the water and the air in such a way as to separate the particles of water and air.
Expansion follows, and the force thus generated is irresistible.
Keely use an "CLOSED CIRCUIT" and the pressure generated inside from the VAPORIC FORCE is ONLY an electron avalanche reaction with AIR that is simple and genial MEDIUM for trapping the bonding electrons.
Air is clearly compressed and water is mixed to air creating an MOIST AIR (ionized).
At this point the MECHANICAL WORK (collision) is an simple way probably used also from Keely , an good example can be the ARMSTRONG HYDRO MACHINE Hydro-Electrical Machine
Here Lord Armstrong don't use the AIR for absorb the bonding electrons.
Him produce steam on pressure with an wood boiler, make partial condensation with an water cooled circuit for produce an mechanic collision on the brass nozzle (with an special design) with the WATER DROPLETS for remove (and absorb) the bonding electrons. As final result in output produce an electrostatic repulsion flow of water droplets positively charged.
Of course.. Lord Armstrong is focalized to produce electrostatic electricity and in fact don't has idea what type of energy has really discovered.. but this is always the HYDROGEN BOND ENERGY!!!!!!!
