Hi all.
I have heard that blank water can be transformed in anything you want it to be. You can pray to it and get some healing effect out of it, you can drop some gasoline in it and the water will take the gasoline properties and burn and so on. I decided to experiment in this area. So far the only way I know how to make blank water is splitting ordinary water in HHO and getting it back by burning the HHO. I made a simple water head out of aluminum for the water to condense. I used aluminum because it transfers heat very good. I circulate some cold water in the aluminum water head so that it stays cool all the time. This is important, because not much water will condense on a hot surface. Then I just point my hho torch on the aluminum surface and recombined water droplets are just dropping in a glass. This works good, in about 10 minutes there is about a sip of water in the glass. The thing is that the water smells like metal and is acidic, I used some PH strips to test it and the water PH is about 4-5. That is weird because I don't know what causes the acidity. I am using KOH as electrolyte and this stuff is strong alkaline. Maybe the water somehow reacts with aluminum and that is why it becomes acidic? I should probably use some food grade stainless steel for the condensation plate.
What are your thoughts about this?
Take it and don't just shake it but pound a closed jar of it pretty hard against a leather pad like a baseball mitt. Do it a few hundred times minimum. That is called succussion. That is your 1X mixture.
