Water hologram
I think to produce the kind of water you are after you would need to burn it in a vacuum otherwise you dont have a pure flame as it is mixing with the surrounding metal and air. The flame is meant to be clear but most i have seen on youtube tend to be a color suggesting that the process itself is dirty or the surrounding air is causing trouble. I saw a guy on youtube simply take a meter long copper tube which had been capped at the end and directed the flame into the tube. The air evacuated and when finished he tipped the pipe up and water ran out so maybe theres a way
I've always wanted to try super hydrated water which distilled or otherwise water which has had hho bubbled through. I guess another thing you could do if your feeling dangerous and are after alkalizing the body is to pass hydrogen gas through an ionizing chamber and breath it. I know of one person that did this and he measured the ph of his urine and it was more alkaline.
As for the biohologram I guy by the name of Rick Anderson use to own a site which he closed which looked into esoteric science. He made a biohologram unit to test the process. I dont think he mentioned how well it worked. He also did the same for regenerating the bodies energy field using lorentz field and made the circuit available. He had a plant that was in terrible trouble. Put it in this box in the dark with the unit turned on for a week or so and the plant came back to life after he opened the box at the end of the time. Anyway here is the url if anyone wants to read and build the units
ELECTMNU
ELECTMNU
