Guys:
Although I have not had problems with the Jt transistor overheating, I have notice that if I remove the led that is across the C and E rail, everything gets very, very hot. If I left it like that, the transistor would melt down. But if I use one low voltage 2 volt red Led bulb there (between the C and E rail), there is absolutely no heat. The point being that it may be important to include at least one led between the rails, even at the expence of it lowering the secondary voltage output, by a little bit. No heat may also be related to longer run times or duty cycles, as there is less waisted energy.
NZ
NZ
Tec
I am still learning the newer electronics My job over the past years have been 3 phase 480 volt industrial Maintenance.I believe the JT or some variation of it could be used for a better power supply sadly I just don't have the skills to be of much help.
