Vaporizer and All:
I am on the same course as far as the solar panels to Jts. I can see that the more leds we add to a Jtc the less amount of Time the small batteries (AAs) are going to last. I'm not getting consistent recharging of the batteries from my Captret to Jt combination, but I'm still working on it, as it looks like there is some hope there.
I am still not convinced that a secondary circuit on the Jt is more economical on the batteries than just a primary C and E connection. I don't care about lighting CFLs, as I don't like their light quality, so I don't see the point in secondaries.
But, I still need more time to work on the secondary aspect to determine if there really are some benefits, other than higher voltage (with no current). Solar panels on the other hand put out LOTS of current along with their voltage.
So, the trick is to use a bigger battery, or less leds. But, if big light is what you're after, the Solar panels are definately the way to go, for now. B class solar cells can be bought for $55 (3 by 6 inch, 36 cells), and one can build the panel oneself. It outputs about 60 watts, at 18 volts. That would make alot of JTc light up, forever, and ever... if there is something that can beat that, I'd like to know about it.
Although there is no magic in using solar panels as a source, they can be combined and connected with many other different circuits.
Conradelectro has mentioned to forget the Jt, and just connect the leds direct to the batteries for the brightest amount of light from the Leds. Although this is true, I think that I'm going blind from looking at the not so bright leds that my Jtc put out, as they are still pretty bright.
Anyways, back to the lab... kitchen table.
MERRY CHRISTMAS, EVERYONE...
Heck, she brought home 2 more last night that are 13watt(60watt visual) that spiral, but a smaller diameter and the glass tube is shorter. I'm anxious to see if the same power is brighter with that style. Besides, I think it's neat to do with a AA or AAA. I don't care for the "warm" ones and they do not put out as much light.
Tec
