Newman Motor
  • Newman Motor
    Hello Everyone,
    My introduction into free energy was with the Newman Motor. My motor consisted of about 9 miles of 30 guage wire of each stator. I have ran some experiments and now I am hoping to move to the Bedini motor.
    However, before I move on, I want to make one last experiment and dont know how to put it together, but the idea how to do it is present.
    How can I collect the BEMF from the Newman Motor? Any diagram or picture help will be greatly appreciated.
    UusedMan
    Hi,
    i did start a Thread before a Time,
    i can get it with a switch.
    I made 2 Diagrams, first one is the general one, and at page 2 is one, what i played around.
    you can find the Post here
      thanks. I will look at it.
      The circuit is adv compared to my basic electronical knowledge.
      can you explain it mechanically?
        wich circuit do you mean now?
          9 Miles of wire? Thats over 47,000 feet! Thats 15 lbs of wire. Are you sure you meant 9 miles?
            The first circuit you had with D1 and D2 included.
            Mark, to be exact on how long the wire, it is 47500 feet per stator. After I am finished, I will have about 95000 feet wire.
            It is only 10 lbs per 47500.
                I got there another Page of a Circuit from the Newman machine
                Maybe you look first theyr Schematics, but they are hard to find anyhow.
                  Pls look at the following schematic and let me know if it is ok.
                  Also, how can i figure out of what kind of diodes to use?
                    I am quit not sure yet about few Things.
                    For the Diodes, i did use any Kind, what i can get.
                    The most can handle about 200V, so they work in general.
                    In doubt you can look at Datasheet catalog for integrated circuits, diodes, triacs, and other semiconductors, view
                    Do you have a original Schematic, where you can go for ?
                    when this thing right side is a Cap, i would leave it out.
                    I have had not good experiences with it. They mostly complete Stop the Current and kinda only swing.
                    I think, this Circle below is the Switch, or the Motor?
                    What do you use for Source, 12V?
                    Therefor, you can skip the first Diode.
                    You got 2 Coils at your Motor?
                    Here you can dload Circuitmaker, a Program, when you wanna make a new Circuit.
                    I would try first more, just to interrupt the Coil with the Switch, and lead it out.
                    When it dont work well, then place the Switch between the Coil, and let the Diode point each time to the other End of the Coil, and still one Diode2,
                    wich you lead the Current out,
                    once before the Diode1 between Coil, once after it.
                    Edit OR you can paint a Plan and scan it as Picture
                    Edit2 Um, about the Diode, not to thick one, they need a lot Current for breakthrough.
                    The most i got are 1n4004 or similar (size)
                      I Have only a motor coil. The switch is to energize the circuit or turn on the electromagnets. I try to close the circuit to a narrow gap to not drain too much power from the batteries. Newman open and closed the circuit numerous times in order to Capitalize on the BEMF.
                      How about the following schematic, can you point to which Diode you are talking about?
                      Awaiting your thoughts.
                      When I first ran the motor, I was using apx. Volts 150+
                        i thought about D3, but it can stay in also.
                        There is maybe something back from the Coil.
                        I think, you should place the Reedswitch at the Place from the the Control switch or instead.
                        even when it doesnt looks a good place for me.
                        I would try it between D2 and the Coil.
                          Err, no, lol.
                          I would put the Switch between Coil and D2/D3, that you interrupt the Coil.
                          that is when it collects BEMF.
                          When the Switch is between D2, the Coil is still in a closed Loop.
                          i think, i do a Circuit too, lol.
                          • #14
                            I did not know how to make a reed switch on the Spice Electronics program. My commutator is a simple wire touching the shaft with electric tape for the off position. It is primitive, but, it does its primary job.
                            I dont know how to use Diodes, so I am going to get some high volts Diodes to start with.
                            you think my schematic will collect the BEMF?
                            • #15
                              I will test today, and let you know later on tonight.
