Perpetual Motion Holder | Edward Leedskalnin
  • Ed's test equipment that I used.
    I wound 1500 turns of 16g wire on each coil, plus 1500 turns of 18g wire on the other single coil used in Ed's notes.
    • magnetic fields gravity waves
      to get antigravity- boyd bushman used two strong magnets in repulsion to cancel gravity when he dropped his magnets in repulsion from a building his magnets hit the ground last. This means that a magnetic field in repulsion cancels gravity, a magnetic field causes gravity, if magnets in repulsion pushes against each other canceling all fields even the earths gavity.
        N/S Monopoles moving opposite each other create Magnetism, N/S monopoles moving along side each other and in the same direction create Gravity.
        I remember an experiment where a frog is levitated by a strong magnetic field, the monopoles in this magnetic field disrupted the monopoles which created earths Gravity causing the frog to levitate.
        L Wippler
        • Sweet Sixteen
          The sixteenth element in the periodic table is sulfur, mixed with iron FES has some unusual properties that need to be investigated further.
          Will continue.
          LWippler I agree, the repulsion of these fields produces antigravity, its a type of shielding.
          • it seems sulfur is abundant in south Florida in the water and soil
              Hi
              If you go for actual PMH, you might as well go all the way through. Ed says in his book that the coils should be wound on aluminum or brass spools that fit on the PMH.
              Looking forward to see your schematic.
              The reason I was getting unusual shocks from my PMH is because it was a short circuit from one of the coil to the PMH
              I not a machinist, therefore any help in tutorials of how to make spools is appreciate. Videos or Books would be great.
              @loadstone
              You seem to be the only one I noticed that has replicate ED work. Awesome! I want to replicate all the experiments from magnet current and post them on youtube for others to see. You seem to have all the components, you wanna do it together?
              • take a magnet with a hole wind electromagnet below both on the same shaft
                the upper end of shaft has a stopper ,magnet if movable ,electromagnet not
                pulse electromagnet to push magnet above
                if you see all device jump into air you have antigravity
                the rest is the construction and energy density required (you have to obtain enough energy per total mass to lift all device with easy)
                as you see there is no antigravity without free energy
                • something like that YouTube - E V Gray 1986 Promotional Video Part One
                  but that seems to be fake
                  anyway imagine the same repeated in Mhz range and with more power
                  • Another view.
                    Hi all,
                    If you start with a horseshoe magnet and wind 2 coils like the PMH and place the keeper gently on and remove it briskly* would probably light a led just like the PMH.
                    Take care,
                    Michel
                    * If you take 2 horseshoe magnets from way back and store one with the keeper on and the other one with the keeper off, The first magnet will keep a good pulling strength as the later one will lose its strength. The old Ones would take the horseshoe magnet that lost its strength and by repeatedly place softly the keeper on its poles and remove it briskly would refresh the magnet to the original condition.
                    http://www.youtube.com/watch?v=jeYscnFpEyA
                    • @uusedman, I can help you with Ed's tests if you want.
                      My PMH is so sensitive that it shows a small a/c current all the time!
                      The current comes from induction, so it must be the stray a/c grid currents or other a/c currents in the surrounding area.
                      Just moving the PMH around in Earth's field makes currents too, but only small.
                      To make spools for the coils you can use aluminum flashing used in roofing.
                      Roll it up and tape it. I made end caps out of 1/16" ally plate, and just held them with tape while winding. After winding I taped all around the coils running the tape through the core up and down.
                      Having said that...my coils are kinda beaten up now but they are still going well.
                      • Defense contractor's anti-gravity discovery disclosed
                        interesting article Defense contractor's anti-gravity discovery disclosed
                        • has anyone tried building a PMH in a figure eight configuration maybe one of the poles will jump splitting the field.
                          • 1.5 volt oscillator set for ringing wave
                            Hello I want to post a jpeg picture of a schematic because I have seen so many great craftsman here. Anyway to help someone develope tesla switch.
                            Also I put ring in there in case I missed something since the wave is very natural and acoustic. try a momentary on switch A. and check out your scope.
                            I hope someone will complete the tesla switch.
                            • Originally posted by Loadstone View Post
                              I believe Ed has been the only person to show Anti-gravity. Visiting Coral Castle well only tell you that he had something special. Everytime I want to work on my Newman or Bedini, I remember Ed's work. Let's go through his book and make videos for our knowledge and for open-source, page by page from magnetic current. BTW, in coral castle entrance there is a sign where is it signed at the bottom "ED". "ED" can be a PMH. flip the design of ED to the right and see.
                              I will buy the Flashing and the ally plate today. Also, I need to buy 10 lbs of 16 gauge of copper wire for the original PMH.
                              P.S. A good website in the USA for copper wire is Para Wire Co, they have good prices. Artistic, Craft, Magnet, & Copper Wire - Paramount Wire Co.
                              • ED
                                Very interesting - ED does seem to like to repeat his initials everywhere.
