Keeping on the subject of the ED in ed, as a symbol. I dont find it for a symbol for PMH but it did inspire me. To the left of the flywheel motor there is a pipe that goes into the ground. In magnetic currents ED said that to make a better coil put it in a pipe. Connect coil core to a metal plate and insert into pipe. A cross section of that would be an "E" . The pipe is big enough to cover both the super norths and souths briefly. So you would get a super south, then both, then the super north in succession from the flywheel/motor. All ringing that pipe (ring twice) which is now outer core of the coil.
I may be wrong, but charging the pipe with the north, and then balancing with the 2 potentials (PMH) and then changing the potentials again with the south lays along the same lines as we are discussing in the Big Bedini motor.
Correct me if im wrong please.
