quick update
a quick update,
excscuse my typing as i have wires ande ttest leads allllll over the place here
i have just put together a small bedini circuit using 12V, charging a 220uF 400V cap...
as the bedini is running i have connected the cap to be not only the output of the bedini but at the same time the coil INPUT to gotolucs circuit..
as its running the cap is holding a steady 70VDC and also the gotoluc circuit is performing as normal...ie..9V powering the 555 half of the circuit, " input bulb" is barely even glowing if at all..output bulb is 30-40% bright.
ok, just twiddled the frequency & duty of the GOTLUC circuit while running from the bedini CAP, and now the cap is holding 130VDC !!!!! witrh input bulb barely glowing ( if at all ), output bulb is usual 40% bright or so, bedini circuit is drawing about 135mA, note that i have not tuned the bedini circuit at all...so its probably possible to get the amp draw down quite a lot..
interesting, as i was twiddling the frequency on the GOTLUC circuit, the bedini motor/rotor was responding by slowing down . speeding up, as was the voltage on the cap.. which is how i came to the point at which its holding 130VDC..
comments?
David. D
a quick update,
comments?
David. D
