Marko Rodin
  • tie it all together?
    It might seem that between the rodin coil, the bedini setup, hendershot generator, hubbard coil & steve marks tpu, there has to be a coherent way to tie it all together to get the desired end result?
    anyone have any suggestions as to get the end result we are all after; a multi-KW generator?
    a number of pickup coils around a large rodin? Multiple rodins? Any ideas Jamie or anyone else?
    • Rodin Coil in solid state oscillator
      Look at the high voltage and decent current from the 'charge' output of this bedini ssg circuit that has gone solid-state and resonant when using a Rodin Coil:
      YouTube - Rodini Solid State - bedini rodin coil combo
      As a group we're all testing the various properties of various coil configurations, all while trying to figure out the best ways to apply Marko's original vision. I would say our various individual goals may differ, but as we are all working together and keeping our knowledge and discoveries shared and public, "it's all good", as they say. The setups differ - I'm still fiddling in bedini circuitry while most of the others are using pulses and signal generators. I actually think they are more on the right track as to how the Rodin Coil is 'supposed' to be used, and I have enjoyed watching the progression. We're all just waiting for a POP! and behold a mini-black hole... heh... but I think we are a ways away - materials probably being the main stumbling block (room-temp superconductor please!).
      Anyways - I'm happy to share the beneficial effects of my Rodin Coils with bedini circuits. The magnetic field vortex is obviously apparent when moving the LEDs around. The 'standard' style coil (copper wire in video) doesn't produce enough external field to light the LEDs, all that action is from the Rodin Coil.
      Any one done any other recent experiments with these recently? Would love to hear some updates...
      Cheers,
      -michael
      • Comment
        • homemade ferrofluid
          YouTube - How to make Magnetic Fluid (ferro fluid)
          Printer toner plus veggi oil makes ferrofluid?
          Worth a try right?
          • New To This Format 1 Post
            HERE IS MY U TUBE SOME GOOD MOST BAD
            LOOK FEED BACK WELCOME
            GUY B
            • Just a nice inside view to revive this topic a bit
              • Simplicity and stupidity!
                Worth a try right?
                Thanks for this, I can kick my hind side for not thinking of this simple
                solution to Ferrofluid! Today I will re-do a number of experiments with
                this ferrofluid to observe what I wished to know!
                • Originally posted by Dogood View Post
                  That big animated gif do not show up on my opera browser at first. I can see it now after I download it.
                  Just curious, after seeing this image, what kind of thing you have in mind that look like it? I vote super ionized atom.
                  • Originally posted by Aromaz View Post
                    Aromaz
                    I thought of an experiment that you might like to try.
                    Fill a tube with this Ferrofluid, seal both ends, and use it as the core for a coil.
                    I'm curious if it would act like a solid ferromagnetic core for increasing coil inductance. It should not retain magnetism and I'm guessing it would have minimal eddy currents. I think it should work well with high frequencies.
                    I would like to experiment with it myself, but am not able to currently, so please let us know the results if you try it.
                    • Originally posted by downunder View Post
                      Aromaz
                      I did before using steel filings in mineral oil (baby oil) but was disapointed
                      with the images.
                      It would not increase inductance - the density of magnetic material is less
                      than in solid. Actually amongst my experiments I found very interesting
                      results with Carbon rod and NEO magnet on one end.
                      I made a mix: grapeseed oil with 2 parts toner and 4 parts ferrite (fine dust).
                      It seems impressive. One of my experiments is with a flat tri-filar coil I will
                      post that with my next video. (coil is somewhat related to Rodin style).
                        Hi Aromaz, you seem quite knowledgeable about electric properties of materials.
                        Could you explain why you used the ferrite anyway?
                        Is it for visual effect or does it help in the Rodin Coil conductivity maybe?
                        • Tying It All Together - The Fundamentals
                          Hi everybody, it's Jamie. I just wanted to bring to you guys some of the things I figured out in the past year working with Marko and this coil. What exactly are we trying to do here? Tap the ZPE? What is it? First I must tell you that I believe we live in a plasma universe that is dominated by electromagnetism and not gravity like our cosmologists and astrophysicists would like us to think. Our universe is electric and our Sun as well as the stars in the sky are plasma spheres fed by intergalactic streams of electricity. I have many reasons to believe this and there is tons of info out there for you to study if so inclined.
                          So what is the ZPE? It is an unlimited source of electromagnetic energy that has zero voltage potential. That is why it is undetectable. The only way to tap the ZPE is to create a differential in it. So using symmetry in your coils will not work. If you look at Marko's enneagram you will see the crisscrossing doubling circuits meet off center. That is a differential and if you were to put an axle through that spot instead of through the center of the circle you will create a wobble when turned like a wheel.
                          Another thing Marko is keen on is that there is no input on a properly built coil. If you think about it the Earth is traveling through space at roughly 70,000 MPH. The ZPE is flowing across our planet at an incredible rate that we don't need to create motion with the input of electrical current or a spinning magnet because the motion of what we are trying to tap is already there! Think along the lines of a dreamcatcher. If you look closely at one it almost looks like the flower of life, and in the flower of life you see differentials everywhere. Just my thoughts.
                          Blessings,
                          Jamie
                          • Symmetry or no?
                            Interesting statement Jamie.
                            I was just looking closely at a picture of aLorenz attractor:
                            One thing that immediately stands out is that there is a lack of
                            symmetry.
                            So systems that oscillate may in fact be a sort of bounded chaos
                            subject to the attractor limits imposed by the "rules".
                            Creating a potential in a medium that quiets down ... like water on a pond with no wind ... involves setting up a geometry, a feedback path,
                            and a slight amount of input. That input might be coming from the ambient waves received all around us. What you want to build is an oscillator
                            that starts to sustain.
                            Our brains look to making machines that have symmetry because
                            we were taught to emphasize balance. Yet nature doesn't exactly
                            have symmetry. Rather nature creates shapes that use the golden ratio ... and then uses symmetry as a second order effect.
                            So one half of a fern leaf has spirals ... and the other half looks "almost"
                            the same .. with similar spirals.
                            When you look at a fern leaf you might conclude it has symmetry ...
                            but you are failing to see that it actually grew by the dictates of
                            the golden ratio ... and that both sides are NOT exactly equal.
                            So yeah ... I think we want to build machines that are kinda lopsided ..
                            like a wagon with 3 good wheels and one that is a bit dorky making
                            the wagon bounce up and down as it rolls.
                            Good insight!!
                            • Negative Inductance?
                              YouTube - Rodin Coil Inductance Vs. Standard Coil Inductance!
                              • I agree that symmetry is not the desired geometry.
                                Look at any crystal, there is a lack of symmetry in the geometry and that is mimicking the massfree energy aether which constructed it....I learned that from UFO researcher David Serada.
                                David Sereda - Zero Point Energy
                                If you want to control the field you must replicate the field geometry....structure and function cannot be seperated.
                                Thats what Tesla was doing when he experimented with different geometries.
                                Symmetry is not always the goal....
