Hendershot Replications
  • Low Freq @ steady state
    Originally posted by mlurye View Post
    Just a little test I did. I was using 12V electromagnet in place of buzzer and 12V lamp(load). Connected FG(function generator) parallel to the load. At low frequencies electromagnet was buzzing but lamp barely glowed, at HF it was other way around. In general it proofed that load and buzzer should be in balance in order for both to operate normal.
    Yeah, I think we want something happening in the range
    of 40hz to 150hz. The buzzer wouldn't be able to go much faster.
    This implies, therefore, that the system must hit a resonant peak
    somewhere within that range -- when at steady state.
    It does NOT mean, however, that it cannot start oscillating at
    a much higher frequency ... and works its way down.
    • Here is another of my ideas.
      I think that all Hendershot discoveries are based on magnetic resonance.
      Any information on what is magnetic resonance and how to use it would be greatly appreciated.
      Mike
      • nuclear magnetic resonance
        Yes I have to agree with the speculation that
        magnetic resonance plays a role
        in Hendershot's device.
        One thing that interested me is this:
        File:EPR splitting.jpg - Wikipedia, the free encyclopedia
        Nuclear magnetic resonance - Wikipedia, the free encyclopedia
        In this graph, as the magnetic field is increased,
        the delta-E can be made to increase.
        If you could construct a device that taps this delta-E
        using the spin-up/spin-down phenomenon, then
        if your source of magnetic field is simply a
        horseshoe magnet, then you have something.
        You would probably need TWO collectors and you
        would then be able to extract the delta-E between them.
        Doesn't this sound like Hendershot's device?
        • Silly experiment I did.
          I took 12V solenoid with soft iron core connected it with Multimeter (set to DC) and was waiving solenoid around. This way I managed to generate 0.8mV max. Without core I'm not getting anything.
          Where this 0.8mV are coming from? Anybody care to look silly and try it?
          P.S. Tried it with 12V electromagnet, same thing.
          Mike
          • Nmr ?
            It's really interesting but can we suppose that in NMR energy E=hv (due to the low frequency v of NMR, in general) deliveries may be added or be gradually accumulated, as the laser effect ? ... Einstein supposed NO (quantum mechanics) if i'm not wrong...
            • gradually accumulated
              Does it have to gradually accumulated to be usable?
              I don't think it does.
              The magnet will be able to create a certain magnetic field ...
              and hence a certain delta E.
              So from a given permanent magnet, you can derive a certain
              delta E -- perhaps.
              The magnet probably can maintain that field -- and not wear out --
              for quite some time!!!
              Permanent magnets can be de-magnetised by subjecting them
              to heat or a sharp blow or by placing them near
              a solenoid with a reducing alternating current.
              So don't do that.
              • So if an external magnetic field (the magnet) may interract with the magnetic spin time (and relax time), the clapper of the magnet could act as a clocked magnetic short circuit to trim the spin effects for the best effects ?
                • I've just read an interesting article about MRA (magnetic resonance amplifier).
                  Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
                  I noticed the use of piezoelectric material... Or I remember that someone said that he felt something like a "heart beat" when in touched the hand made capacitor with the Hendershot device running. My thought is that it might be a reverse piezoelectric effect. Does anybody think that it is possible the wax was only used to seal a piezoelectric material ? Maybe Hendershot used a common piezoelectric material in the gap between the coils and the capacitors ? A common material like quartz or...sugar ?
                  • Hendershot materials...
                    In the documentation, there is a reference to "carbon rods" ..
                    which is kinda bizarre since you don't see much more about that
                    in any photos ...and its not mentioned very much.
                    The combination of aluminum, copper and carbon
                    and perhaps other chemicals like manganese oxide,
                    ammonium chloride ... would behave like a carbon battery ...
                    The battery would be coupled -- physically -- with a tank circuit ...
                    and as such, might behave a bit like an AC generator ... not a DC
                    battery.
                    Its possible the author mistook the dowel pegs -- made of wooden
                    material -- for "carbon rods".
                    Carbon in there might boost energy density -- like done
                    in modern day double-layer capacitors.
                    piezoelectric is also an interesting idea in that when
                    the fields between the coils and inner capacitor STRESS,
                    this would put pressure -- physically -- on the layer of material
                    in-between.
                    Another idea would be some material subject to Casimir Effects ..
                    or not even that ... but rather just the sloppily hand-made capacitor
                    having its plates perturbed and wiggled, producing spikes and
                    irregularities.
                    I found that my hand made cap is absolutely unstable -- capacitance-wise.
                    I can bump the table ... and its value will change. Its subject
                    to vibration ... because its not sealed up in wax like Hendershot
                    would do after tuning everything.
                    Such "glitches", for power generation into coils, however, is a good
                    thing -- unlike careful RADIO design.
                    I'm experimenting with using these Hendershot-like capacitor cylinders at the end of
                    auto ignition coils ... driven by various chopper circuits: Joule Thief, Aromaz's circuit
                    or a 555-2n3055 circuit, etc. A signal generator would probably work too.
                    Anyway, I find that I can create a field that is quite large around the cylinder -- upwards
                    to one-half meter in radius. LEDs using AV plug, or NEONs just held near ... with wires .. not touching.
                    Days later my hand was all dried up -- like it was sun burned. The field is strong here -- watch out.
                    The capacitor cylinder emits a much larger field than the ignition coil .. or other coils.
                    The cap is like an antenna ... transmitting side.
                    I find that a coil placed within the proximity of this cap can pick up energy -- wirelessly.
                    Yet, if you place another unconnected CAP nearby, you cannot light a neon or AV plug from
                    that other cap easily off of the 2nd cap ... not until it is real close ... or touching.
                    So cap as transmitter ... coil as receiver .. works very nicely.
                    Cap as transmitter ... cap as receiver ... not so good.
                    Coil-to-coil is well understood transformer.
                    Coil as transmitter ... cap as receiver ... again probably not so good because
                    the coil doesn't have a large field around it like a cap produces.
                    • Another test I did.
                      I connected both L4 sequentially and on open ends connected signal generator (12V). To my surprise on right transformer I found 180V AC. Left side didn't have any voltage on it But I don't have my 110V electromagnet yet, but I should get it soon. Hopefully it will make a difference.
                      P.S. Forgot to mention, L4s were resonating at 200kHz.
                      Mike
                      • Originally posted by morpher44 View Post
                        I think those "carbon rods" was home made resistors, as I remember i read somewhere he used home made carbon resistors.
                        Until you seal those coils with wax,your capacitance would be very unstable. After a good sealing, it has to be very stable. I made myself a lot until I finally succeed, same capacitance in both coils. I used paraffin, as hendershot did.
                        Anyway I think there is an important part of the device missing from every Hendershot document. The switching part! I believe he used one. I think the magnetic vibrator (ferromagnetic metal, with axis in the center) was the moving part of the switch which when moved in the axis, caused changing magnetic field in the coils, the frequency of the magnetic field change would be proportional to the frequency of the vibrating metal piece, quite low. If he managed somehow short the coils (the whole circuit), when the vibrating metal piece was at the right position, he could get much higher frequency,with the same metal piece movement.
                        Interestingly we can cause high frequency oscillation, ringing in any coil by only just waving a magnet nearby at the right plane, and shorting the coil at the proper time.
                        • I found this post very interesting Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze (...seem to be suggesting that any (magnetically???) resonating coil will give OU - and all you need to do to catch it is have a capacitor plate at right angles to the magnetic field - this will generate more power than input....)
                          Tesla's electric conversion is also a key feature of T. H. Moray's radiant energy device; "we have discovered the oscillation of the universe corresponds to oscillation of electric capacitors." Quoted from "The Sea of Energy" 5th edition - p.238.
                          Mike
                          • Hi All
                            Here are some of my thoughts re Hendershot design. I am a little handicapped right now because I cannot access youtube, scribd or Apsden.org whom I am going to refer to.
                            If you go here and download the 32Meg version of Hendershot Mystery:
                            Lester J Hendershot - The Hendershot Motor/Fuelless Generator - Hyiq.org
                            At the beginning is a good back engineered attempt with possible schematics of all the variations. Towards the end are hints on how to wind the coils with sliding pegs to raise little by little as the windings grow.
                            Harold Apsden has a free energy design using the concentric capacitors as radiant collectors. I believe also Hendershot's son thought the concentric capacitors were used as antenna. I believe this is also true. But I think what is being collected is scalar energy, not the magnetic spectrum as we know it.
                            You can go here and download Chapter 11 of Patrick Kelley's Free Energy Books where Apsden's Great Britain patent GB2390941 is described. Apsden uses the same concentric capacitors as Hendershot. Notice similar symmetry of design.
                            When you wind coils over the pegs of the basket-weave design, the same wire goes around the circle of pegs and when it comes around the second time, the wires cross at 90 degrees to the first winding. This is the same 90 degree crossing as appears in the Wilbert Smith Caduceus Coil. Think of the 90 degree crossing of the wires as a transducer converting electromagnetic energy into scalar energy. You could dump 1000 watts of energy into the caduceus coil and it would not get hot. It just swallowed it up like a black hole. So, where did the energy go? It got converted and sent out into space as scalar energy. Naudin did experiments with this design as a transmitter.
                            The Soliton Pulses Generator experiment by Jean-Louis Naudin
                            Here, the 90 degree basket-weave coil design together with the concentric capacitors are working as tunable receiver of scalar energy that is everywhere, but not detected with conventional electronics. By stimulating the coil with the buzzer coils make/break, the Hendershot basket-weave coil also sends and receives scalar energy. By tuning in with resonant circuits coupled with regeneration or feedback, this huge stockpile of scalar energy is converted back into usable electrical energy.
                            If I am right, then it might be possible to substitute the complicated basket-weave coil design with a trifilar wound caduceus coil wound around a doughnut shaped form. The concentric capacitors could then be placed in the center of the doughnut.
                            Easiest of all would be to build like a mobius coil design. Here you would take the length of wire required to get the correct inductance for tuning. Let us say 100 ft. We will have 3 wires each 100 ft long representing L1, L2 and L3. Stretch them out and secure one end. The other end we clamp into a battery powered hand drill and wind the wires up, twisting them ever tighter until we get them at about a 45 degree angle. These 45 degree angles cross each other at 90 degees to create the scalar junctions. There are different ways to wind up the long length of the twisted trifilar wire into the final coil. You can search mobius coils.
                            Sorry I am not in a position to do any experiments. I just wanted to express my thoughts about this subject.
                            Tishatang
                            • The most interesting is comment made by Alfred Hubbard here Alfred M. Hubbard: Coil Generator
                              • hubbard coil thread
                                @boguslaw
                                Yes I started another thread on Hubbard in this forum. I'm also very interested in the Hubbard coil ... hoping there is a common insight here for these technologies.
                                I believe the mathematical constant PHI may hold the key.
                                Hubbard used PHI in his coil design.
                                I realized that this is simply due to the number of of outer cylinder coils
                                he placed around his larger core cylinder. That geometry optimizes
                                with those PHI relationships. The math just works out that way.
                                With 8 coils around 1 larger coil, you get those PHI relationships.
                                I realized that if you put 6 coils around a 7th, that instead all
                                cylinder diameters should match. I've built a 7 coil thing
                                to experiment.
                                Meanwhile, I think Hendershot may have also used PHI.
                                I've done a video on that as well if interested.
                                Recently, I've gotten very interested in writing a simple
                                bit of software to plot PHI golden ratio spirals ... and last night
                                my Son and I made a fascinating observation.
                                My program plots these PHI spirals such that you can create
                                as many of them around a central point as you want,
                                each a different angle starting point. This produces a
                                hypnotic looking set of spirals around a central point.
                                Next, using time, I would alter the starting angle each
                                150mSec tick say, so that the collection of spirals would
                                rotate -- even more hypnotic.
                                By adjusting the number of iterations ... number of spirals
                                drawn, certain values yielded a standing wave FROZEN
                                appearance. So many are drawn that when they are re-drawn,
                                each 150mSec tick, they would land on the locations the were
                                before -- giving the visual appearance of no movement.
                                Yet, interestingly ... you would occasionally see little light-bursts
                                in the spirals ... little glitches. I don't know if this is a
                                Pentium bug with hardware floating point ... a memory glitch ...
                                or an actual mathematically phenomenon, but it occurs on my
                                PC. I have to try it on more PCs.
                                Meanwhile, following the Marco Rodin, Nassim Haramein thread,
                                I see that Nassim also had a cad-cam sort of program drawing
                                PHI spirals -- wow synchronicity.
                                YouTube - Nassim Haramein and Marko Rodin's Eye of God Part 2
                                I had no idea.
                                His observations were ... a sort of lining up with Marco's diamgram...
                                one ... but also a sort of standing wave pattern in the forms of
                                rings ... depending upon iterations.
                                Interestingly, I am not able to reproduce rings .. .per se ...
                                but I do see artificats which might be due to digital pixals trying
                                to represent perfect curvatures. I see CROSSes ... and
                                CHRYSTAL shapes ... as I boost the iterations of the spirals
                                to higher and higher values.
                                But now for the fun part....
                                I grabbed the window, while the spirals are being drawn ...
                                and dragged it around on the screen to show my son
                                the interesting pixel artifacts while moving the window ...
                                and he said ... "Hey, those patterns we see look like a magnetic
                                field emanating from the center".
                                He was right. There were what looked like magnetic field line
                                patterns that would appear when these spirals being drawn
                                are put in motion on the display ... as the window is dragged.
                                The geometry of PHI - Golden Ratios ... is fascinating ...
                                and it makes absolute sense that magnetic field lines ...
                                and particle movements would be subject to PHI spirals ...
                                which would explain why all life ... and all things in nature
                                FORM with such spirals.
                                It is the organizing principal of energy movement.
                                So regarding placing some solenoid 90 degrees with a capacitor or
                                something .... don't think so right-angly like that.
                                Think in terms of PHI!!!
                                Hubbard started his coil design when contemplating the
                                flower of life!!!
