Originally posted by dunfasto
I admire your tenacity, but Now I KNOW you do understand what you are writing about in this thread.
This not only regarding your proven lack of comprehension regarding circuitry, but now also your understanding of fundamentals regarding induced magnetism, and especially the caduceous coil which is so not the same as CW+CCW arrangements.
Hendershot used CW+CCW windings on his tin can (ferrous) sleeve.
The true purpose of CW+CCW, or for using a caduceous coils is to induce a magnetic vortex, and in this regard Hendershot used an extra centre winding energised via a series connected phase shifting capacitor to induce field rotation.
It is the magnetic field vortex which leads to electricity generation, and not as you imply !
Also CW+CCW is not a magnetic cancellation >
*** it is more like a magnetic spring ***.
After creating the magnetic vortex, this arrangement can return unused electromagnetic energy back into inductive drive/load circuitry.
Within a caduceous coil the fields at the 90 degree crossover points still add axially, as both are in the same winding sense; ie. both are at 45 degrees with respect to the longitudinal axis.
Where the caduceous is different is that it is more like a 'magnetic end fire' device when it comes to impulse energisation, or to field alternations tuned with respect to the length of wire used; which is why its may be manually adjusted (essential) inside another winding to induce a central magnetic field vortex region.
Fabrice Andre clearly understands what he is doing with his caduceous coil, but caduceous coil energisation is not essential.
And 50Hz produces an electron avalanche ?............... ???
Cheers ........... Graham.
