Originally posted by Core
Whoa......... Man, I hope I'm wrong and completely misunderstanding you. But if I'm right then everyone from Russia to the U.S. is going to feel a bit foolish.
Ok, a static charge is like a high pressure gas. I can place a static charge on an object or part of a coil with an HV emitter plate. So if I wanted my coil to absorb a positive charge from the ambient a negative HV charge would be required to electrically induce this condition. The other part of my coil would receive a negative charge from the HV positive emitter plate. This negative part of my coil is tied to a thick and robust ground wire to facilitate maximum negative ion attraction.
Now in this coil I have a high pressure gas, AKA a heavy static charge that was induced by HV transformer. By itself these charges are harmless and rather worthless. My analogy would be that in one side of my coil I induced a hydrogen charge and the other side I induced oxygen. Clearly I have to keep them separated until I am ready to mix and make water.
I need two coils that I can easily combine into one. The bifilar becomes interesting when you install a 'spark gap' between the two coils(center). This small spark gap allows you to charge each side of your bifilar separately, the total charge I assume calculated via Coulombs Law. Firing the spark gap will convert our static charge to kinetic energy but we still need more. Now we need our oscillator to magnetically excite the coil. I imagine we do not need a very large one but just enough to induce a current, fire the spark gap and join the bifilar to allow mixing. The oscillator adds the magnetic component to the coil.
The output would be the combination of the electrically induced static charge and magnetically induced charge. Maybe the 566IC with its duel outputs is the ideal one.
The big question is 'Does electrically inducing a charge on a coil increase its output when magnetically excited?' If yes then the excess energy comes from Coulomb's Law, something that people have been chasing since the days of Ben Franklin.
Sounds way too easy.
-Core
-Core
be essential for replication because this is a superiour material.
