Originally posted by Slider2732
The coils I've been using so far with this simple SEC thing are apparently exactly the same ones as Johnny Davro was using. I know he's posted this link but they also look exactly the same as the ones he got out of the disposable cameras.Trigger Transformers : Trigger Transformers : Maplin
As I say I tried it with the 2N2222, so as far as I can tell I used exactly the same/correct components, and yet it doesn't work. That's what I don't understand
And I know there isn't something fundamentally wrong with my basic setup, or me for that matter
because it worked with a BC182. So I'm stumped.I'll try your LED suggestion tonight if I have time. Otherwise hopefully my 40x BC182 delivery will arrive tomorrow and I can try those out.
Does it make a difference whether you use a 1N4001 or 1N4148 etc though? I would have thought not, except I tried running the SSG without a charging battery, supposedly just as an efficient motor, but I kept the 1N4001 instead of using a 1N914, and the neon was stuck on. I assume the neon isn't supposed to be on when it's a motor and not an energizer/battery charger, but the only difference in my circuit was the diode, so is using the right diode that important?
Thanks for the info
The brighter the LED, the stronger the wireless field and how well it is all working.
Also I'm getting a small spark (plasma?) off the toroid on the top of the coil so I was intrigued and wanted bigger sparks
Keep going
