Thank you zhorv324,
my coils have thin wire because the total DC resistance is 36 Ohms, however, the amount of turns is very high compared to yours so the Inductance is high @ 370mH. This is the reason I decided to try these ready made coils because looking at the Flyn instructions of only 4 layers and spread out so wide I had a feeling it would use too much current to create the magnet field needed.
There is a well known coil geometry that will produce maximum Inductance for a wire length. I have a program that calculates this. Most of the time the coil layers (height) are about equal to the width and the center of the coil diameter needs to be a larger then most of the coils we wind.
If anyone is interested in this great free coil program here it is: Coil Maestro - freeware coil/solenoid calculator
There are many other parameters that need to be considered when making a coil. An important one that is often overlooked is the time constant. I think when making a motor this one would be important.
Looking forward to everyone's thoughts
Luc
Luc
. So I used a coil of a shaded pole motor and stuck two AM radio antenna ferrite bars in for core and got the motor turning faster (315 RPM) and using only 4 ma @ 2.84vdc. I also collect the flyback without effects to performance and have 4vdc on the 10K load. There is also next to no change when I load the motor now.
