Mr hartley's schematic 1936 fig 1 p.91, fig 3 p.93 shows the 2 mA
Parametric Excitation
Parametric Excitation of a Linear Oscillator: a Manual, by Eugene Butikov
More background material...
http://is.gd/FerdinandCap -- patent precedes Chris Carson's replication by a couple of years.Originally posted by Vinyasi View Post
Index of /circuitjs1/texts/Parametric Excitation -- includes patent, above.
PE Hacks
The PE for this circuit won't work if loaded into Paul Falstad's electronic simulator at his website since he's upgraded his software to eliminate stray charges, immediately, rather than allow them to dissipate gradually as is the case with his year old software that I downloaded and continue to use on my website although with modifications of my own...
http://is.gd/electricparadigm
It's stray charges, alone, which I foster and nurture into a roaring bonfire using PE to do it without any assistance from a battery and there's not enough energy from this circuit's two aerials to be useful. I made them that way figuring I didn't need them as an AC source, but as tickling references providing some beat frequencies which may explain this circuit's randomness.
This one works since it comes precharged...
http://is.gd/electricparadigmprecharged
But this one overcomes suppresive limitations with explosive PE...
http://is.gd/paraboom
It's amazing how easily we are stumbling our way into alternative energy...
Free energy is misunderstood. But that won't stop us from pursuing it....
Take this fellow on YouTube...
http://is.gd/pexamp
Plus this explanation...
https://vimeo.com/vinyasi/ledpara
And my examples...
References...
https://youtu.be/iK5OFpZyOzo
https://youtu.be/WZlUzQo670U
https://vimeo.com/vinyasi/synelectcap
https://youtu.be/0wPtq4nMeQ0
https://youtu.be/t25inqKzLaU
http://is.gd/paratexts
Tesla's Variable Vacuum Capacitors
Since Tesla invented these devices, and since it's one of the two methods for exercising Parametric Excitations (besides inductively), it may certainly serve as an alternative to the use of an air based dielectric used by Chris Carson's build or Ferdinand Cap's patent.
A quick search on eBay yields a number of finds all of which are in the pico range, which at first did not seem promising, but then thinking about it a little, why should it be a problem if it's motorized same as Chris or Ferdinand's devices? So what if it takes a little longer to achieve the same result? I think it's better that way since there will then be less likelihood of overshooting whatever target the user/operator has set for themselves and prevent ending up with an excess of energy and a new problem of getting rid of it as fast as possible.
Slow growth is best.
Inductively Adjustable Explosive Synthesis of Electricity
In the course of failing to implement a 10pF to 500pF sweep patterned off of the variable vacuum capacitors available on eBay, I managed to succeed at implementing explosive synthesis of electricity - not by adjusting a capacitive parameter, but - by adjusting an inductive parameter in parallel with the capacitor which I had formerly been sweeping downwards and upwards.
But since this circuit is predicated on the kaboom circuit, I can't get a nice output. Rather, another nasty jolt of explosion - but this time, via inductive adjustment.
A mere incremental increase from 4μH to 5μH does the job provided this circuit is simulated with equivalent series resistance and its parallel capacitor is held at 1F. Without equivalent series resistance, this circuit wants to explode without the need to raise the 4μH coil. And without this parallel inductor, the capacitive transition between nothing happening and this circuit immediately exploding with excess energy is a fraction above 1F. So, rather than attempt to deal with a difficulty the hard way, I elected to make the phase transition the easy way.
The fractional adjustment of the 1F capacitor - without a 4μH parallel coil being present alongside it - was the difference between 1.0000005942F and 1.0000005943F: a difference of 100pF.
Thank you Mark Dansie!
A lot easier than trying to break into Wikipedia. This guy actually offered to publish whatever I wrote!
Electrical Energy: The world is not as we perceive it to be - Revolution-Green
It was an outgrowth of my comments here...
Quantum Energy Generator - Revolution-Green
Any comments or corrections would be greatly appreciated.
Using a solar cell module as a parametric oscillator
While trying to solve the mystery of Sangulani Maxwell Chikumbutso's parametric metamaterial, I've decided that it must be made of silica in the form of a solar cell module or else a quartz crystal oscillator. I reversed the logic in my normal reasoning ...
If sunlight can place a voltage difference across a solar panel, .... and
If a voltage difference can alter the dimensions of a quartz crystal oscillator, ... then
A voltage difference across a solar panel may alter its dimensions enough to also alter its capacitance.
So, I made another one of my parametric excitation circuit simulations incorporating this concept, ...
Circuit Simulator Applet ported to JavaScript by Iain Sharp, from the original in Java by Paul Falstad, Used Here to Promote the Simulation of Surges Arising from the Judicious Use of Negative Resistance.
... and then looked for confirmation online...
But what about Sangulani's claim that he is irradiating his parametric metamaterial with radio waves, not varying voltages directly as I am postulating?
Perhaps my circuit simulation hints at an interpretative answer? What if his use of the term, "radio waves", is patent speak for the electromagnetic (inductive) influence which coils have on parametric capacitance? Then, these "radio waves" are not being sent through the air so much as through the circuit itself. Maybe....
Saith Motors - World's first Self Charging Electric Car -- a YouTube video
https://groups.google.com/d/msgid/te..._source=footer -- more info
h t t p : / / t i n y u r l . c o m / s o l a r o s c
h t t p : / / i s . g d / p a r a m e t r i c s a n g u l a n iLast edited by Vinyasi; 07-02-2018, 06:47 PM.
I feel pretty juicy today...
For I have determined that reactive and radiant are one and the same thing. Nothing mysterious here, except that standard theory poses reactive to be a problem not waiting to be exploited, but rather avoided.
Ossie Callanan and Dave Bowling may have discovered that a dead fully sulphated lead acid battery is a simple alternative to synchronous generators/motors or Jim Murray and Paul Babcock's SERPS or analog computer caps and coils for converting reactive power into usable generative power.
Energetic Forum - View Single Post - Tesla's Electric Car
I've been suspecting that Eric Dollard's analog computer qualifies as a parametric amplifier for some time.Originally posted by Raui View PostPP-18/AR Voltage Converter
I have also been thinking that a solid-state device would be easier to get going than a rotative device which was confirmed by my friend because there are too many variables in rotative devices. By use of this method or the use of specific configurations of magnetic amplifiers I think it would be quite easy to achieve parametric excitation and as long as the energy used to change the capacitance is less than it generates we have energy to power a load.
Raui
Jim Murray says, of his Transforming Generator, that each coil modifies the mutual inductance and, hence, impacts each other's self-inductance as it runs.
There are three stages of development to posing Eric's analog computer (in LMD mode) as a power amplifier...
1a. The first stage reiterates what Eric says of the synthesis of electricity that, "it can't be done in small quantities smaller than what is equivalent to the utility grid's substations, namely: 500 kva" -- if memory serves me.
1b. So, I came up with a simulation in Micro-Cap, Berkeley SPICE, which uses large transformer coils and large banks of capacitors, but is unstable with non-uniform waves and periodicity...
http://vinyasi.info/energy/analog-co...6+L1+L2-ON.jpg
2. Then I managed to simulate waveforms with constant periodicity, but only by injecting a fictional negative parallel resistance into each of the four LMD module's capacitors which resulted in the additional benefit of shrinking the mass of this circuit's caps and coils...
http://vinyasi.info/energy/analog-co...t-L1+L2-ON.jpg
http://vinyasi.info/energy/analog-co...oltages-ON.jpg
3. Neither of these two versions are buildable (#2) or desirable (#1). So, that prompted me to ask myself the question, "How can I both scale it down and make it non-fictional in its design?" At first, I thought that it had to be a rotary capacitor similar to Chris Carson's. Or else, exhibit some property or another simulated by Sean Logan. But, I don't understand the math, because I am not formally trained in this subject.
{In fact, I hate doing too much math. So, I've elected to be like a blind Edison and stumble my way through countless hours on various simulators varying every possible parameter until I get results and learn a knee-jerk skill at the same time. Then I have to turn to people like Eric to help me to understand my experiences and justify my virtual successes.}
So, I returned to my blind belief that, somehow, Eric's analog computer will give me a solid-state device which can modify its own parameters while it is running. I have Jim Murray for additional motivation since his presentation at one of the conferences on his Transforming Generator does just that.
It's not perfect, but the following simulation manages to not costing a whole lot of input to stimulate a "runaway surge" escalating in an exponential manner towards infinite oblivion unless regulated by some sort of solid-state safety mechanism (as yet, unknown to me to successfully work for this particular circuit), or good-ole fashioned mechanical relays -- if they can switch fast enough; or else this simulation's reactance can be slowed down. This can usually be done by reducing the input frequency, or by varying the inductance and capacitance.
{On some of my prior experiments, I managed to vary the virtual growth rate of a simulated surge from as low as nano seconds to as high as half a day. So, at least in theory - generally, speaking - I know this can be done.}
-- Eric Dollard’s Analog Computer As A Power AmplifierKinetic energy is non-changing (in the *big* picture) in as much as all gains and losses are accounted for resulting in “no free lunches” of energy.
Yet, reactance cannot maintain itself. It must inflict self-induced alteration of the amplitude of whatever energy is indirectly affected by it (via alterations of frequency, capacitance and/or inductance) whose result is the same amplitude per greater or lesser unit of time giving the illusion that energy has been manufactured out of thin air. This mistaken assessment is due to our ignorance of the relevance of timely reactance serving as a form of potential energy which must alter the units of time - per units of energy - as a side-effect of reactance. So, no energy has been created, nor destroyed. Time has been shrunken or expanded while maintaining the same quantity of energy.
Besides frequency, potential energy comes in two other formats: capacitive and inductive reactances. Both are potential forms of energy in that both have the ability to either store kinetic energy, or dump kinetic energy, making them a potential source for kinetic energy and, thus, manipulable by reactant techniques.
The process of manipulating reactance is called: parametric excitation (amplification). There are several techniques for achieving this.
Some techniques involve the rapid rotation of a variable capacitor outfitted with plates containing gaps. Another technique is to slide one coil into, and out of, another coil to vary its magnetic coupling over time. Another technique is to position components near each other and in pairs so that the field-effect of one component can modify the parameter (of capacitance or inductance) of the other component while the circuit is running.
Another technique is to rapidly open and close relays (mechanical switches), or arc a spark gap, since these are well known to induce surges (energy spikes) or kill them based on where these are placed within the circuit.
PS...BTW, Electricity has nothing to do with the common miscomprehension of the Conservation of Energy Law. The use of the word, "energy", is inaccurate and a misrepresentation (ie, a lie). The only way to apply this law is regarding calories (heat). So, the correct statement is, "Heat IN equals Heat OUT".
I managed to simulate #2 in LTSPICE, but it's output is similar to that of #3 in that both surge an exponential hyperbola of infinite gain. And before I tried simulating #3 in Micro-Cap, I simulated it in LTSPICE, but with results similar in both cases. So, I'm still seeking that elusive holy grail of constant periodicity (along with free energy) in order to accommodate a PWM interface between this style of energy/reactance amplification and any one of our numerous household appliances.
http://vinyasi.info/energy/analog-co...ic-LTSPICE.jpg
http://vinyasi.info/energy/analog-co...gs-LTSPICE.jpg
And I managed to add poor solder joints to attempt to be more realistic. It worked! At first, it killed the overunity. But, then, I managed to overcome this obstacle.
http://vinyasi.info/energy/analog-co...der-joints.asc
http://vinyasi.info/energy/analog-co...der-joints.plt
Now, the only obstacle is its lack of self-oscillations to prevent it from blowing itself up...
In a sense, we're studying the artistry of electrically blowing stuff up...
If we were to study the electrical behavior of a chemical bomb becoming detonated, and removed the chemistry, and duplicated the electrical activity in a circuit, we'd probably have an explosively parametric circuit!
This is why I believe in spontaneous combustion suspecting that it is an electrically reactive event well before the oxidative chemistry kicks in to convert the electrical buildup into rapid oxidation. Thus, it's already too late to try and stop it once it becomes noticeable.
Managed to discover a simple method to turn OFF Eric's analog computer, power amplifier (electricity synthesizer) by merely removing the mutual inductances acting as the sole linkages among each of the LMD modules.
And found a quotation of Eric's worth sharing.Last edited by Vinyasi; 07-08-2020, 09:14 AM.
good to see so much posts on this topic.
I believe I have a parametric resonance going on. funny thing, is that the resonant voltage and current become inphase.
the L2 primary coil that I use is series resonant, with an superemposed negative voltage impulse.
The L3 secondary coil is excited by both the impulse and the sine wave of the primary.
in series with the secondary is the L4 Extra coil (as Tesla called it).
This coil is the one that is parametrically excited. by L3 and the L2 impulse.
L4 is at 4 octaves higher than L2 and L3. But still produces a single sine wave at the L2 L3 frequency (4 octaves lower). and as said with voltage and curren in phase.
I need to be able to tune it perfectly so all 4 coils are tuned, but its rather tricky.
words are much to hard to describe it.
this video of mine shows this.
That is fantastic Evo! One of Tesla's secrets has now been opened to the public. A user of another forum some time ago made found this too, then he just went silent. Let me see if I still can use PP. This changes everything for the design arena. Hope others will see the Key.
thay
