Originally posted by 7imix
Originally posted by cikljamas
Yours already OU if you use it as water warmer
.Since you have two battery, see if you can charge the bigger battery. Parallel it with cap.
If you want to charge the source battery, how about making another stingo just like what you have now and use the capacitor to power it and charge the battery?
Creating secondary and charging source is impossible for me because connecting any of secondary terminal to the battery kill oscillation. So I guess second stingo is needed.
Originally posted by SeaMonkey
- stingo PNP is triggered by coil spike or something like that
- stingo PNP in inverted mode half the input current requirement
- stingo NPN base only connect to the PNP terminal without route to ground or resistor in between.
That circuit is different from stingo. But feel free to compare result.
My goal is driving transistor with spike, I would prefer the simplest version of stingo if possible.
But did you use the version with capacitor?
I think gyula miss the point. You show that you can make something oscillate without discharging the source battery. If you keep reading same high voltage at the capacitor then the circuit do some work, capacitor will reduce charge if there is nothing to charge them. Meaning there is work to keep charge level of capacitor but you achieve it without discharging source battery.
I think measuring input current is not a big deal. You can hear the stingo sing, the battery voltage do not decrease, and yet the amp meter show positive value. The amp meter must be lying or unable to detect what kept the source battery voltage stand still.
Keep in mind that stingo work differently from other radiant circuit. Stingo consumption reduce with load. So suggestion from other circuit experimenter may not be relevant or applicable to stingo.
Which stingo version that you use? single diode or FWBR recovery?
. Safer for me without cap
