I did some measurements on the spike duration. On my first coil with the secondary shorted and no load, the spike duration was 12usec. The highest voltage on the low voltage side was 29 volts as calculated by my meter, but it must be performing rms calculation on it because the scope is way off the charts on the spikes. The scope goes to 100 volts. The voltage fell off as i adjusted frequency to either side, so I figure that must be the resonant frequency of the coil. The frequency is 7.5khz.
On my other coil, I couldn't get it to oscillate with the secondary shorted. With the secondary open, the spike had a much gentler downslope and the spike duration was therefore 70us. The peak voltage was 45 volts and the resonant frequency was 1khz.
