Single Ferrite Bead Core/Coil Test
Hi folks, I tested my single ferrite bead core/coil in repulsion and it works pretty good.
Though I have confirmed that the coil still gets warm at 24 volts when holding the shaft to draw the same current as with all 5 steel bolts and 1 drive before.
So I was exceeding the amp capacity of this wire and still am with this core/coil.
Though I would say, the pulse on time is probably on far too long and that would solve the issue.
I noticed the flyback charging is much better though and also that when I'm using 24 volts input, normally if one charges a 12 volt battery off the flayback, it tends to increase the input amps.
Though my setup is not doing that.
I will now make the other 9 core/coils, since I'm using the 5 core(10 total) 6 magnet rotor configuration for now.
Here's a pic of the single coil test setup.
Uploaded with ImageShack.us
peace love light
tyson
peace love light
tyson
