Hi tornarod, thanks for sharing that test. I will be testing my single coil/core today sometime and gather some data.
here is a pic of what my makeshift bobbins look like.
Uploaded with ImageShack.us
peace love light
tyson
Magnet Biosing
Hi there everyone,
Just thought id share this with everyone . When i add a bunch of neo magnet's and put them on top of my charges which have ferrite cores the amp draw goes down with the same settings by about 1/3 , similar to what Rod has shown but in a different way . interesting . Cheers JasonLast edited by N O G; 09-12-2011, 07:24 AM.
Is that the same for both N or S pole of the magnets when attached to the ferrite core? if i reversed the magnets the effect changed by the same amount in the other direction.Originally posted by N O G View PostHi there everyone,
good idea. thank you. I will use this on my Muller dynamo. Plastic bolts are hard to find.Originally posted by Cherryman View PostHi All,
Still parts gathering, but i wanted to share this. I already shared it at the neighbours, but it might come in handy.
To easy adjust the spacing i suggest a strong magnet, attached to a bolt or screw.
Happy building.
you will need to go to a model airplane store and look at accompany called Dubro.
Why DC - DC Converter
Hi Toranarod
I had a look at some of the specs for DC-DC converters and I would expect, to change the voltage of DC will require it to be pulsed for some sort of transformer action. The devices seem to operate at a high freq - upto Khz, so I wonder if the converter is being used as a form of PWM to reduce current?
Just my thoughts.
John
Well you could also try a children toy store, they have all kinds of "simple" toys using plastic or wooden screws.Originally posted by toranarod View Postgood idea. thank you. I will use this on my Muller dynamo. Plastic bolts are hard to find.
Magnet polarity
Hi there Rod,Originally posted by toranarod View PostIs that the same for both N or S pole of the magnets when attached to the ferrite core? if i reversed the magnets the effect changed by the same amount in the other direction.
Yer when i flip the magnets it draws more . umm . cheers Jason
There is one very important issue with a DC to DC convert that nobody has addressed. I have used them before for other projects. they are not 100 % efficient. they need a lot of power to operate. So even if you connect nothing to the out put of the dc to dc converter they will load down your generator considerably. Here is one of the most efficient switch chips on the marketOriginally posted by john_g View PostHi Toranarod
Just my thoughts.
John
I will give this one a try. if the motor can run its self and run the Dc to Dc converter we will have a winner.
Screws
I did think about that too, and you could use ust simple Wood to Drill a Thread on it. To lock it, you can use another Piece of Plastic with a Thread.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
[quote=toranarod;140411]There is one very important issue with a DC to DC convert that nobody has addressed. I have used them before for other projects. they are not 100 % efficient. they need a lot of power to operate. So even if you connect nothing to the out put of the dc to dc converter they will load down your generator considerably. Here is one of the most efficient switch chips on the market
I will give this one a try. if the motor can run its self and run the Dc to Dc converter we will have a winner. "[quote=toranarod;140411]
Hi
He did mention to use a 90% or higher efficient dc dc converter.
I think it is also very important to use an isolated dc dc converter that use a toroid or e core transformer for isolation in "non refective" fashion...
That way you don't need all that Jb style switching.
Here is a explanation by Konehead how the regauging works. Keep and mind that kone's drawing is for a repulsion motor but as he explains he has the magnet wrong in the drawing . So it is actually as we want to use it. Coil will atract rotor and magnet will repulse it after motor pulse.
https://sites.google.com/site/altern...c-pulse-motors.
VissieLast edited by nvisser; 05-13-2011, 06:25 PM.
