Trees as radiant energy collector
  • from http://www.energeticforum.com/new-me...c-table-3.html
    Originally posted by AetherScientist View Post
    thanks, I'm reading it.
    check this too: Amazon.com: The Cosmic Octave: Origin of Harmony, Planets, Tones, Colors, the Power of Inherent Vibrations (9780940795204): Cousto: Books
    About the picture of "a better..." maybe the geometries of the chemical elements are related to "cymatics". A combination of longitudinal frequencies can create complex geometries and structures. Remember that each chemical has its own "scalar signature". That means, a multi-frequency pattern of electric fields.
    i 'll refer you to this thread: http://www.energeticforum.com/renewa...phenomena.html
    i did a research on magic square and ended up in a site, hold and behold, talking about fractals in nature
    Magic Squares
    Another source of transcendent proportion is based upon an arrangement of numerials within adjoining squares such that their total adds to the same value in each column; vertically, horizontally and diagonally.
    "Patterns of Nature" Sacred geometry, Phi, Fibonacci Number
    Indeed, As i mention in all my post, in layman terms "everything is fractal", considering this simple statement, you would imagine that behind every apparent law that controls the universe are just an effect example:spatial resonance, lies the true cause: ie Fractal Resonance.
    see also: http://www.energeticforum.com/renewa...-crystals.html
    Now let's consider this the electromagnetic spectrum is also a Fractal/Constructal system
    in that case it should obey the same law as all fractal/constructal system:
    The constructal law puts forth the idea that the generation of design (configuration, pattern, geometry) in nature is a physics phenomenon that unites all animate and inanimate systems, and that this phenomenon is covered by the Constructal Law stated by Adrian Bejan in 1996: "For a finite-size (flow) system to persist in time (to live), its configuration must evolve such that it provides easier access to the imposed currents that flow through it."
    in other words, it should obey the
    E=M3/4
    It is called Kleiber's Law.
    It states that the energy needed by an organism at rest (not doing any specific exercise), is not proportional to its mass, but sub-linear.
    It can be attributed to many factors and one of them is that the more massive an organism/element/wave is, the less surface per volume it present. If the organism is represented par a sphere of diameter D, volume scale with D^3, but surface scales with D^2. But energy produced by the body is proportional to volume, while energy lost is proportional to external surface.
    To sum up, a little body loose a lot of heat and its little body can not sustain it. Therefore there is a lower limit to the size of hot blooded animals, which is bigger than the one for cold blooded ones.
    watch this video
    YouTube - ‪Fractals: frequency, the heart, and cancer‬‏
    the same holds true for the table of Elements
    see post#23 http://www.energeticforum.com/147095-post23.html
    Signs and symbols -Confucius.
      one more info, which is of great importance, i know you guys would agree with me :
      Water on the Sun?
      Water Found on Sun
      note: meet your coil/fractal antenna to harvest sun energy and it also confirms why:
      and it does make sense when i read post #58 written by sucahyo , with just one minor detail i would change, it is not electricity the true cause that triggers the change in the trees but the water present in it reacting to water present in the sun:
      Just to show you that i was not the first one to think of this concept:
      one last for the road: guess what is toroidal and is dependent on the sun's rotation:
      Heliospheric current sheet:
      and don't forget the presence of water in the sun and you have your Cosmic Water Coil capacitor, containing your earth water coil, containing your tree water coil, and so on (sounds fractal, no?)
      If you want to understand the world as a system then you need to investigate three key components.
      Cycles your 3
      Fractal patterns your 6
      Exponential functions your 9
      ;the smaller you get (on the cosmic scale), the bigger the voltage , this is your exponential function
      [B][U]
      If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.
      Heliosphere - Wikipedia, the free encyclopedia
      from quantum agriculture (see below)
      any thoughts on what i have posted so far
      heehee, enjoy
      Solar Wind Changes Atmospheric Pressure Over South Korea - Technology Review
      Evidence is growing that interplanetary magnetic fields can have a significant influence on our weather
      see post #37: http://www.energeticforum.com/138939-post37.html
      Henrik Svensmark - Wikipedia, the free encyclopedia
      His work presents hypotheses about solar activity as an indirect cause of global warming; his research has suggested a possible link through the interaction of the solar wind and cosmic rays. His conclusions have been controversial as the prevailing scientific opinion on climate change considers solar activity unlikely to be a major contributor to recent warming, though it is thought to be the primary driver of many earlier changes in climate. Henrik Svensmark
      Global distribution of atmospheric water:
      The Water Cycle: Water Storage in the Atmosphere, from USGS Water Science for Schools
      • from post#194
        Fractal Landscapes
        Generating Random Fractal Terrain
        Self-contacting Symmetric Fractal Trees and the Golden Ratio
        The fractal proportions of a single tree have been scientifically proven to mirror the distribution of trees in the entire forest. The implication is one of mutual support between all naturally evolved entities within a given ecosystem.
        in other words a tree is fractal antenna within a larger fractal antenna (the forest)
        • about post#197
          and Vedic Science seems to agree with me
          watch this 9 min doc....
          ‪Greatness Of The Vedic Vedas Knowledge Perfect Science Part 3 of 6‬‏ - YouTube
          • BTW: when you watch the above doc, i would like you to remember two things:
            As above so Below
            and the Moe-Joe Cell
            (see http://www.energeticforum.com/144797-post48.html )
            ps: there is a diagram being talked about (at 3:00 min ) i think it is worth exploring it with Tesla in mind
            • i would really love to have some feedback on what i have posted so far...
              • A combination of longitudinal frequencies can create complex geometries and structures. Remember that each chemical has its own "scalar signature".
                a better way of saying it is "everything is fractal", considering this simple statement, you would imagine that [B]behind every apparent law that controls the universe is a fractal/constructal system
                • I posted this a while back but it looks like a essential info in the quest of understanding
                  side note
                  From the info I have posted so far (and if you do a little research ), you 'll see that there is a trend that appears, and that is for every fractal structure you have seen in nature/universe, the presence of water comes hand in hand
                  • opened a new thread to explore the application of fractal in society also known as socionomics ( or The Wave Principle of Human Social Behavior )
                    • Please could someone DRAW a BIG 3 6 and 9 for me I will show you something
                      • [IMG][/IMG]
                        • in other words Fractal Systems are the Universe's Hidden Engine
                          • btw
                            • Thanks
                              Now you should see it ,right ?
                              It has no meaning except shape.... look at shape....
                              • Wyniki Szukania w Grafice Google dla http://www.educate-yourself.org/dc/IM2011coils%20321.jpg
                                6 and 9 are pancake coil in opposite directions
                                3 is a center tapped coil
                                Tesla said that in those SHAPES is encoded key to Universe, meaning to every force in nature.
