The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • I also can't help but to notice that in the picture of the 'standing wave' that when the two vorteces begin to converge they form what appears to be the exact shape of a UFO ie a thick plane with a buldge protruding in the center. At first I thought it was a little odd then I thought well in most things the UFO would be the physical representation of the standing wave. When it is formed this would obviously be the optimal shape for absorbing every ounce of energy produced; not only the main input but the "A" vector as well. Imagine that in ice.
    • Originally posted by shawnnweed View Post
      they all got inspired by the standing wave
      I imagine we'd need some piezoelectric powder (tourmaline / quartz ) in the middle of the ice along the "A vector field" , water being fractal will act as an Antenna (yes we did forget about the Fractal Antenna property of water )
      COHERENCE AT ANY LEVEL IS COHERENCE AT AL LEVELS. (same for INCOHERENCE)
      An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. This harmonic cascade of inter-connected-ness is the structure of our hologramic universe
      thanks Shawn
      Signs and symbols -Confucius.
      • The Caduceus Coil
        Transmutation patents
        US2003226401
        Atomic structure recognition and modification method and apparatus Inventor: LETOVSKY HOWARD
        Also published as: US2005145031 // US2005155340 (A1)
        Abstract -- The present invention provides methods and apparatus for determining the precise makeup of atomic and molecular structures, as well as providing the capability of modifying said structures. The invention uses induced resonant frequency wave effects to define and modify the electromagnetic, electrical, radioactive, atomic weight, and co-valent bonding characteristics of matter. One embodiment of the present invention may produce directionally controllable magnetic fields in gaseous media that interact with magnetically polarized vehicle surfaces to allow high-speed, highly energy efficient inter-planetary space travel. Another embodiment of the invention may neutralize waste products remaining from nuclear fission power production. The invention utilizes controlled multi-spectrum frequency induction to catalyze changes in atomic structures that may include: focused and dramatically amplified release of energy relative to natural states of matter; production of new alloys; transmutation of dangerous organic compounds into non-toxic media; and controlled polarization of matter. The benefits of the invention may include highly efficient interstellar spacecraft propulsion systems, hazardous waste elimination systems, efficient electricity production, and health enhancement of biological organisms.
        patent: Atomic structure recognition and ... - Google Patents
        Spiral coils generate very powerful electromagnetic fields by operating with two different but simultaneous resonant behaviors. Quarter-wave resonance is established by adjusting the frequency (and wavelength) of a radiofrequency (RF) voltage source until the length of the spiral conductor is equal to 1/4 of the wavelength of the alternating voltage. This generates an electromagnetic standing wave with at least one peak node and at least one null node. Inductive-capacitive (L/C) resonance is established by optimizing the thickness and width of the wire ribbon used to make the spiral coil. When inductance and capacitance are balanced, the current response will synchronize with the voltage input, creating in-phase behavior, minimal total impedance, and maximal power output. If two such coils are placed near each other, they will create an extremely powerful electromagnetic field between them, which can promote chemical and plasma reactions involving charged particles such as ions or plasma particles, possibly including nuclear fusion reactions (Leon Sprink got the Same results .
        ELECTROMAGNETIC SYSTEMS WITH DOUBLE ... - Google Patents
        note: the two spiral coils should look more like the first picture i posted than the one in the patent (more like a cousin to Tesla's Bifilar )
        The same coils should be used to create the Ice Battery (at lower voltage )
        • time to pdf print
            • Or something like this: It's called a Fermat Spiral
              It is also called a Fermat's Spiral -- from Wolfram MathWorld
              Fermat's spiral (also known as a parabolic spiral) follows the equation
              in polar coordinates (the more general Fermat's spiral follows r 2 = a 2θ.) It is a type of Archimedean spiral.[1]
              In disc phyllotaxis (sunflower, daisy), the mesh of spirals occurs in Fibonacci numbers because divergence (angle of succession in a single spiral arrangement) approaches the golden ratio.[3]
                If any of you guys making those crystal batteries (see also : http://www.energeticforum.com/156873-post548.html ), i would highly suggest growing them sandwiched between two coils as mentioned previously...if it can transmute as was said in the patent, it would be a breeze to grow crystals under the same condition on a lower more accessible voltage (even use solar panel to collect energy to power the coils to grow the Crystal Batteries )
                Principle of correspondence
                Slider's experiment
                [/QUOTE]
                and it is scalable (like cement battery )
                • Slovenia just posted a great link:
                  Nikola Tesla Plates and Tuning Anodized Aluminum with Alternating Electromagnetic Fields | Helpfulwaves.com
                  My work with tuning materials with compound frequencies as a designer electromagnetic field from an audio coil points back to Tesla and solves a mystery surrounding how anodized aluminum plates, discussed on the internet today, can have electromagnetic characteristics that affect the body in helpful ways. Perhaps it can be said to be a form of Free Energy, free in that once the field is tuned, using the designer field from the electrical coil, it is enhanced and permanent. No additional source of energy is needed to keep it active. However, you are not going to be able to power up your mp3 player with it. The designer electromagnetic field affects/influences biological systems.(reminds you of previous posts doesn't it =
                  The area specific weak magnetic fields are described by these noisy atoms in the medium of sound, converted into electrical audio signals and then replicated as an electromagnetic field from an audio coil playing back the recording. They can be detected in the recording and matched by one sensitive to weak magnetic fields. The truth is there is a weak electromagnetic field for all matter with its own unique field frequency.
                  About growing Crystals Batteries in between the two Coils
                  As I mentioned at the beginning of the article the mystery surrounding the Tesla Plates has been solved. Nikola Tesla and others most likely knew that a designer electromagnetic field tunes material. As the information was passed on it no doubt became distorted with fanciful ideas. Most people today do not even know that tuning of materials using designer electromagnetic fields can be performed. Remember this, the key to tuning is a precisely matched designer field
                  • What Georges Lakhovsky did not know, but others associated with Nikola Tesla seem to have understood, is that a designer oscillating electromagnetic field can be imprinted or tuned into a host material. I use the word tune as the term magnetize does not exactly fit for material that is not thought to be magnetic such as aluminum, glass or silicone wristbands. The tuning, in my opinion, is enhancing the molecular electromagnetic weak field of the material and this field is also taking on the characteristics of the matched electromagnetic field applied from the electrical audio coil.
                    from the same website
                    A Mobius coil has a unique characteristic of cancelling out electromagnetic frequencies unlike that generated by a regular electrical coil used in the tuning process. I have been exploring other ways to work with designer weak electromagnetic fields that have a positive physiological affect on the body. For tuning material, that is held or worn near the body, a standard electrical coil is used while playing selected designer mp3 audio files.
                    how to make their version of a mobius coil
                    Comparing a Mobius Coil to a Regular Coil - YouTube
                    Shawn Check out this vid on the mobius coil
                      http://www.quantumbalancing.com/news...lenodecoil.pdf
                      Richard DAVIS
                      Non-Inductive Resistor
                      The Problem:
                      To develop an electrical resistor that has no residual mutual- or self-inductance at high frequencies.
                      The Solution:
                      A Moebius strip made of insulated resistive materials with electrical leads attached directly opposite one another provides a noninductive, nonreactive resistor which is simple, inexpensive, and flexible in usage, and can be made to almost any desired size and shape....
                      ....Two ribbon conductors of equal length are affixed on opposite ends of a strip of dielectric. The assembly is then given a single twist and the ends are joined to form a Moebius surface. The ends of the conductors are soldered together and the resistor terminals are attached to the directly opposed solder joints. Current applied to the terminals will travel in opposite directions, so that the electromagnetic fields cancel each other, resulting in an essentially noninductive, nonreactive resistor with a low time constant. Bifilar wire may be used instead of resistive ribbon, eliminating the need for a center dielectric strip. Thin film conductors on flat surfaces can also be used to make Moebius resistors.
                      Two or more sets of resistive wire may be mounted laterally on the same nonconductive strip, with about 1/16-inch spacing, and connected to form multi-Moebius resistors in one unit. There is no change in the time constant of the individual resistors, nor does one in any way affect the operation of the others, even when they are assembled in parallel or series.
                      The performance of the Moebius resistor is unaffected by its form, size, or length. Once it is connected into a Moebius shape, it can be folded or around around a cylindrical core or a card, or even into a ball, resulting in compact packaging of the resistor for use in miniaturized circuits. The Moebius resistor does not couple to metallic objects, external fields, or itself. When the bridge is nulled the resistor can be handled or changed in form without disturbing the balance. The conductors must not be touched and the spacing between them must not be altered.
                      • Did you know the Ancient called Saturn , Lord of the Rings. you learn something new everyday
                        • Check this out, a lot of what we talked about has been discussed in this conference
                          but you guys are a little more informed
                          Review of ExtraOrdinary Technology 2011
                          Jamie started off with a call for using an older A-432 tuning standard rather than the Nazi mandated A-440 tuning used by most musicians today. He pointed out that the foremost advocates of the newer tuning standard were high officials in Hitler's government, and that it creates a form of tension in most people.
                          Then he brought up conference Technical Director, John Fiala, who had suffered a severe wound from a practice mortar round last October that involved second and third degree burns. Healing had expected to take about two years. John described using a multi-frequency Rodin Coil built by his son and finding his healing time reduced to about four months!
                          Jamie then stated, "Marko's work is in coherence with Pythagorean tuning."
                          • also from the same article:
                            Jamie then stated, "Marko's work is in coherence with Pythagorean tuning." He recommends that all device builders look at their work in terms of music, which is embedded in the universal vortex.
                            Marko said math is really a visual language, his work is the missing energy in the universe, and then showed a number of calculations on painted glass doors. A so-called "VW" figure with the digits 1 through 9 arranged around it shows a symmetry of numbers that can then be used to calculate various kinds of coil windings. If one tries to include zero as a number in this figure, it collapses. On the other hand, nines permeate the universe. All number sequences run down to 9 ultimately.
                            COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
                            John Milewski
                            Much of the work covered in this presentation involves Ormus, which is key to growing gold on glass or air. Some researchers have had indications that Ormes can be in black sand magnetitie. It is some intermediate form of matter that a few people working with alchemy have found over the past 25 years. Ormes is a gas. Metal precipitates out as a metal. At higher temperatures you can get iridium & rhodium to precipitate. Silver dissolves in nitric acid. Anything that crystallizes has Ormus in it. We need to have someone with an understanding of conventional chemistry to look at this Ormus.
                            • Here is a nice playlist on structured water featuring Clayton Nolte
                              Inventor and Author Clayton Nolte Introduces Structured Water - YouTube
                              compare the 369 image with the geometic shape and the (8p 8n/1p 1p ) position (as if you split the molecule by joining the two ( - ) in the inner circle
                              • According to Researcher Clayton Nolte and Schauberger (applicable to coils cw and ccw )
                                Left spin is Feminine also called creative Energy , Right Spin is Destructive Energy
                                VII. The Principle of Gender.
                                "Gender is in everything; everything has its Masculine and Feminine Principles; Gender manifests on all planes." - The Kybalion.
                                This Principle embodies the truth that there is GENDER manifested in everything-the Masculine and Feminine Principles ever at work. This is true not only of the Physical Plane, but of the Mental and even the Spiritual Planes. On the Physical Plane, the Principle manifests as SEX, on the higher planes it takes higher forms, but the Principle is ever the same. No creation, physical, mental or spiritual, is possible without this Principle. An understanding of its laws will throw light on many a subject that has perplexed the minds of men. The Principle of Gender works ever in the direction of generation, regeneration, and creation.
