Principle Of Mentalism: The Universe is all Wave / Principle of Correspondence
from http://www.energeticforum.com/psychi...antenna-2.html
Within a coherent system, the range of the coherence (coherence length) becomes the constant quantity instead of the velocity. This makes frequency proportional to velocity apparently without restriction, so long as one remains within the coherence length. There can be many velocities each with a proportionate frequency; there can be as many frequencies as there are possible velocities. Frequency no longer has an absolute value, the system has become fractal in frequency.
As a consequence, effects can occur in many different parts of the electromagnetic spectrum all originating from the same source which might be chemical, biological or electromagnetic. It is this which links effects of frequencies characteristic of chemicals to technological frequencies and through to the frequencies of biological systems ( see my post#20 through 22 http://www.energeticforum.com/136257-post20.html ). It is also the reason why environmental frequencies can mimic a chemical exposure for hypersensitive patients carrying a toxic body-load of a matching chemical. Table 1 shows the fractal frequencies generated by imprinting the optical spectrum from a mercury discharge lamp into water.
COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. This harmonic cascade of inter-connected-ness is the structure of our hologramic universe
Caduceus coil + Vogel Crystal + Rodin Coil + Solfeggio and you the water container the perfect Combination if you look at it closely
your Truth Resonates loud and clear with me
