Originally posted by GChilders
My internet has been down. I have found over the years that a lot of problems with circuits and components is that they are not soldered correctly and a dry solder joint is not a good joint and is hard to detect.
When you solder it is not to good to overheat the joint BUT by the same token the joint must be soldered correctly any solder joint must be heated just enough so that the solder becomes fluid and then the Iron must be removed. Here are some good soldering sites so please look and study them.
EEVblog #180 - Soldering Tutorial Part 1 - Tools - YouTube
EEVblog #183 - Soldering Tutorial Part 2 - YouTube
EEVblog #186 - Soldering Tutorial Part 3 - Surface Mount - YouTube
I am sure after studying these Video's you will be pleased with yourself when you actually solder your parts into your PCB's.
If in the future If you do have a problem and it may be related to your soldering Using your soldering Iron place it onto the solder joint for a split second and raise it again keep doing this and you will notice that the solder becomes fluid/like a puddle remove the Iron and when the solder is solid it must be a shiny surface.
Kindest Regards
Monsters seem to travel slowly.
. Do not ask me if you insist on one simple answer only!
