[QUOTE=ntc;239922]
Those caps will possible not get the energy stored because of their inductance and they might make your PSU unstable.
The right measure will be to add a choke in series to + and then the big cap.
Choke: any transformer. Connect the low voltage coil as choke coil and short circuit the high voltage coil. See Utkin where he explains how the inductance increases considerably when a winding is being shorted out. It is like adding a flywheel mass to the shaft of a motor.
If you have a transormer with 2 secondaries you connect one to + and the other to - and short ciruit HV winding as well. Thus you get a current compensated choke (common mode choke).
Alterntively you might find those chokes as well at washing machines, older computer monitors, MOV and other electric equipment. Scavenge
JS
JS
AND Oshpark
