3 Battery Generating System
This topic is closed.
had not read this postOriginally posted by tachyoncatcher View PostYes, he/we did/do. Going back to the same post.
We have found that when the transducer has seemingly reversed its polarity, that is when we get the most benefit from ambient. I suspect this is because the ambient is opposite "normal" electron flow and is positronic and electrostatic in nature. This condition is setup by the "vibration" or resonance injected by the motor and the load placed on the system. The transducer, as a battery, has the ability to create a chemical dipole. The transducer, as a capacitor, has the ability to collect the ambient which is excited by the "vibration" and balance the vacuum caused by the load. The transducer, as a magnet, has the ability to maintain and amplify the "vibration" once initiated by the motor.
Randy
but now i see what he was trying to do
..... so simple as he said ... vibrating Russian Dolls
shouldn't the motor be then asymmetric
.... http://www.energeticforum.com/renewa...energy-86.html ( always good to know )
ps : Thank you for your drawing .... it makes it so much easier to interpret
not quite as familiar with the electronics symbols
would probably work for this version of 3BGS .... with An Asymmetric Motor
Dave has built and tested with the Asymmetric Motor. He reported positive results before the motor came apart. We are testing different PM brushed topologies. So far we have had the best result with a standard universal, series wound, PM motor.Originally posted by MonsieurM View Postwould probably work for this version of 3BGS .... with An Asymmetric Motor
Good Luck,
Randy
just a " dumb" question .... but if you replace the motor with SSTC 12V - Solid State Tesla Coil - YouTube ... wouldn't we have a better effectOriginally posted by tachyoncatcher View PostDave has built and tested with the Asymmetric Motor. He reported positive results before the motor came apart. We are testing different PM brushed topologies. So far we have had the best result with a standard universal, series wound, PM motor.
Good Luck,
Randy
on the vibes
see also : 12v Solid State Mini Tesla Coil with Circuit Diagram - YouTube. This condition is setup by the "vibration" or resonance injected by the motor and the load placed on the system.Last edited by MonsieurM; 11-05-2013, 08:27 PM.Signs and symbols -Confucius.
One of the best runs I ever had was with UFO's modified "Asymmetrical" motor. I was able to run loads off the inverter and the primaries increased in voltage during the run.
We have been using stock, off the shelf motors simply because ANYONE can do the experiments with those motors. If we can get a setup that gives us stable performance, then adding a modified motor will only enhance the results.
Just curious if anyone here has seen T. Townsend Brown's patent for a battery. Simple to build and supposedly, once charged, it supplies endless voltage
DaveLast edited by Turion; 11-05-2013, 09:37 PM.
Chapter2 - Magnetics
LutherG explains the "why not" with this system, better than I ever could.Originally posted by MonsieurM View Postjust a " dumb" question .... but if you replace the motor with SSTC 12V - Solid State Tesla Coil - YouTube ... wouldn't we have a better effect
on the vibes
RandyOriginally posted by LutherG View PostIts about magnetic field polarity and memoryLast edited by tachyoncatcher; 11-05-2013, 09:57 PM.
you mean the following link : Townsend Brown Battery Patent ApplicationOriginally posted by Turion View PostOne of the best runs I ever had was with UFO's modified "Asymmetrical" motor. I was able to run loads off the inverter and the primaries increased in voltage during the run.
The active ingredient of the subject battery is a massive high-K dielectric material, such as heavy metal oxides or carbides
Thank you .... will have to check on what he means by Memory ....Originally posted by tachyoncatcher View PostLutherG explains the "why not" with this system, better than I ever could.
Randy
also check out James Y Johnson -- Dipolar resonance -- Anomalous dispersion bands , believe he came to the same conclusion as other mentioned discoverersLast edited by MonsieurM; 11-05-2013, 10:41 PM.Signs and symbols -Confucius.
from the description looks very similar to :Originally posted by Turion View PostMonsieurM,
That is the patent I was thinking of. I have a paper copy of it in my notebooks.
A New Oxide Of Copper Battery
just Townsend took it to the next level
ps / most of these Inventors / Discoverer seem to love Wires deep in the Ground ( earthing ) ..... and i don't think it is because of how we perceive grounding today .... Tesla said Earth is like a metallic ball ( with insulation around ) ... Moray ... Rota .... etc same pattern
makes you wonder
Townsend Brown "Rock" Partial Patent Application
Partial PRELIMINARY PATENT DESCRIPTION "Rock"
T. Townsend Brown
BACKGROUND:
Careful observations, conducted over a period of years, have revealed the existence of a "steady state" electrical self-potential spontaneously developed by certain semi-conductors. Exploratory work with various semi-conducting material has revealed massive high-K dielectrics, being heavy semi-conducting materials with high dielectric constant, produce the greatest self-potential. Solid dieliectrics such as barium titanate, lead zirconate titanate and certain natural rocks (granite, basalt, etc.) are found to produce this electrical self-potential. The origin of the self-potential referred to in this application is believed to be not hitherto known or identified. It is not piezoelectric, pyroelectric or electrochemialc in origin.
Tesla's Colorado lab was located in a highly geomagnetic location.
Magnifying transmitter - Wikipedia, the free encyclopedia
and Clemente lived in the canary islands : The distribution of basaltic volcanism on Tenerife, Canary Islands: Implications on the origin and dynamics of the rift systems
if you have to look differently at a Battery ( ie Condenser ) ... it would be appropriate to also look at other parts of the system differently
what you call ground is actually made of multiple Strata ( Stratum - Wikipedia, the free encyclopedia )
.jpg/250px-Quebrada_de_Cafayate%2C_Salta_(Argentina).jpg)
in terms of frequency ..... it can be viewed as a gradient ( Pressure Gradient - Geography For Kids - By KidsGeo.com )Last edited by MonsieurM; 11-06-2013, 01:11 AM.Signs and symbols -Confucius.
Electret
The Townsend Brown application seems very similar to the process of making an electret capacitor, beeswax or carnauba wax seems to bee the key. Do a google search with "capacitors that recharge themselves pdf".
This and pulsing a battery inverted is one of the things I intend to try when I'm done with the scalar charger experiments.
Mario
First attempt of 5BGS
Hi All
Yesterday I tried my first attempt to replicate the 5BGS and after along process of killing my two new AGM battery and then pulsing them according to what Dave recommended but I used basic stamp instead of Arduino and then my two batteries became both -1.2 ,-3.5 to be used as a transducer and drain my third AGM to 11.95 to be used as a buffer battery and I did all the connection according to Randy diagram but when I start the circuit the motor didn't run and I didn't use my hand to turn it because it was late and every body was sleeping but I have noticed that one of the traducers flip polarity and became positive +5.6 and the other one became negative -5.6 and my motor was loaded by another motor the same motor to be use later as a generator all my battery was SLA battery and they are all 7.2 Ah I used different automotive bulb as a load on the buffer battery .
I am using hand made plastic coupling for the motors I am still waiting for the coupling I ordered as Randy refer in one of his previous post my motors are ZY6812 they are 24vDC 120W.
I still can not figure why the motor didn't run but mor test will be done and mor details to be posted .
Any recommendation will be appreciated .
Ehsan
Take the wisdom even from the mouths of the insane
Ehsan,Originally posted by ehsanco1062 View PostHi All
Ehsan
Try running the motor on a 12v battery. If it won't start on that, you may have a problem with the motor. I have not used transducers made in that fashion, so I can't speak of their performance. It sounds as if there is not enough impedance in those 2 transducers. Disconnect the positives and put a AC cap rated for 24v or greater between the positives. If it then runs, then I refer you to Dave who has experience with those type of transducers.
Good Luck,
RandyLast edited by tachyoncatcher; 11-06-2013, 09:28 PM.
are you familiar with Radiation pressure - Wikipedia, the free encyclopedia
According to Maxwell's theory of electromagnetism, an electromagnetic wave carries momentum, which can be transferred to a reflecting or absorbing surface hit by the wave.+The radiation pressure results in forces and torques on the bodies that can change their translational and rotational motions.
It is true that a dielectric may for a very long time retain a part of its charge. I have electrified blocks of paraffin which at the end of 18 months retained a weak residual electrification. But it is evident also that dielectrics very quickly lose a great part of their electricity, because a rod of ebonite excited by friction, of which the potential may exceed 1500 volts, loses the greater part of its charge in a few minutes. It is even astonishing that it should not disappear quicker, if we admit that the quantity of electricity retained by a body is kept on its surface by the pressure of the insulating gas and of the equally insulating ether which surround it. When there is no longer equilibrium between these antagonistic actions, the electricity partly escapes.
Gustave LeBon: The Evolution of Forces ~ Part IIsee also : http://www.energeticforum.com/241881-post601.htmlGerry Vassilatos and Tesla
Imperative toward obtaining the desired rare effect, the capacitor and its connected wire lines had to be so chosen as to receive and discharge the acquired electrostatic charge in unidirectional staccato fashion. The true Tesla circuit very much resembles a pulse jet, where no back pressure ever stops the onrushing flow. Electrostatic charge rises to a maximum, and is discharged much more quickly. The constant application of high voltage dynamo pressure to the circuit insures that continual successions of "charge-rapid discharge' are obtained. It is then and only then that the Tesla Effect is observed. Pulses literally flow through the apparatus from the dynamo. The capacitor, disrupter, and its attached wire lines, behave as the flutter valve.
in terms of frequency ..... it can be viewed as a gradient ( Pressure Gradient - Geography For Kids - By KidsGeo.com )Last edited by MonsieurM; 11-06-2013, 08:49 PM.Signs and symbols -Confucius.
Yes, but can it travel down a wire? Does is have amplitude and phase? Wait a minute... "which can be transferred to a reflecting" hmmm.Originally posted by MonsieurM View Postare you familiar with Radiation pressure - Wikipedia, the free encyclopedia
Randy
Hi RandyOriginally posted by tachyoncatcher View PostEhsan,
Good Luck,
Randy
I have five of these type of motor with different power 120w,200w,300w and they are all turn even with 6v power no problem with that issue ,but I will try use capacitor between the transducers and see what is the problem but I don't know whether the motor should turn immediately or it will take time as the 3BGS ?but I have noticed that the buffer battery voltage did not increase during the test !
Ehsan
