3 Battery Generating System
This topic is closed.
I hear you on the not having enough time, thank you for the response.
I am thinking a MY1020 run at ~12 volts differential and the highest temperature rated magnet wire available as a start.
As an extreme measure forced air cooling like in video related can be generated from one motor running a homemade Tesla turbine force injecting air into its own casing and the casings of some other motors: https://www.youtube.com/watch?v=pnmpt9BQk_0
I remember seeing a post showing a ferrite mold made in a 3D printer.
Is it the core or the windings that overheat?
Matt,Originally posted by Matthew Jones View PostIf you do not know how to use a diode bypass circuit you have never built a monopole energizer. Diode Bypass for inductive loads. Learn!!!
Matt
I just attached a SSG to the 3BS and it worked really well. I am not sure why I have never looked at in like this before! Now I am wondering if you even need the little scooter motor at all.
Thank you,
-Altrez
Crystal.
https://en.m.wikipedia.org/wiki/File:Brookite.png.
A brookite crystal, how amazing is that?
Question
Ismnuts,
In whst way does the Kibble balance put a “nail in the coffin” of an OU generator? I have one sitting on the bench at my old house. In fact I have 3 different versions. No nails or coffins in sight.
Now I honestly have NO IDEA if the generator I built can be perfected to run long term because of the heat issues with the iron cores and the fact that ferrite cores, while causing less heat, may also produce less power. But it is absolutely possible to build a machine that, while it is actually running, puts out more power by MANY TIMES than it takes to run.
Just because YOU haven’t seen it doesn’t make it untrue. Anyone who has a rotor with large neo magnets on it can PROVE that to themselves by properly building a SINGLE coil correctly. It is NOT rocket science. But you do have to actually build something.Last edited by Turion; 03-04-2019, 01:25 AM.
Same BS
No, it is not.Originally posted by Turion View Post... But it is absolutely possible to build a machine that, while it is actually running, puts out more power by MANY TIMES than it takes to run.
The real world (reality) makes it untrue. Physics describes that in detail.
You say anyone can prove it to themselves by building something. But apparently no one can prove it to someone else. If what you say is so, why is there not a single example of it available for me to see?Originally posted by Turion View Post... Anyone who has a rotor with large neo magnets on it can PROVE that to themselves by properly building a SINGLE coil correctly. It is NOT rocket science. But you do have to actually build something.
It is not rocket science to know what you say is untrue. It is far beyond rocket science to actually accomplish such a feat.
A generator outputting 1800 watts while using only 300 watts, like you claim to have, would revolutionize the world as we know it. It would be the greatest machine ever built. Yet you keep the only one in existence packed away in a box too busy to save the planet. Thanks.
Lol
Hi there bi,
I was wondering how long it would take you to stick your nose in. After all, that's all you're good for. You won't build it, so sticking your nose in and opening your mouth is all you can contribute. And you're right about one thing, you are spouting the same old BS.
Don't blame me for the problems of the world. I have contributed a solution here. It's not my fault that so many choose to listen to someone like YOU instead of me.
There is absolutely NOTHING in physics that 'describes in detail" why my generator won't work. There CAN'T be. Because it works.
AS I asked before, which of the claims I make about this generator do you believe are false?
1. That a generator can be built that produces 2000 watts? (That would be 12 coils producing about 136 volts at 1.2 amps each)
2. That it can be turned by a motor running on 24 volts at 12-13 amps (around 300 watts) If this is your choice, it would be the correct one, because this is where modern generators FAIL.
3. Or that 70% or better of the 300 watts can be recovered. (3 battery system) And this isn't even NECESSARY with a machine this big because of the inputs and outputs. Just use a stock motor and run it off a couple batteries and live with the losses you have because of the GAINS you are getting. Unless you are like ME and just LOVE running stuff nearly for free.
Speak up. I can explain how to do it in terms even YOU can understand bi. But I know your responses. You don't want an explanation of how to do it, you want it done for you and proven before you can be bothered to do the research, because that's the kind of researcher you are. No exploration or discovery, just "researching" things that have already been proven work.
Just simple proof... All I ask
Turion,Originally posted by Turion View PostHi there bi,
I have read your explanations before. They don't make sense. That is why I want to actually see it or see proof of it.
1) Of course a generator capable of 2000 watts electrical power output can be built. There are likely millions of them. What is impossible is to produce that 2000 watts of power output while delivering only 300 watts of input power to the generator.
2) A generator rated at 2000 watts can be turned with a motor using only 300 watts BUT NOT while it is delivering the 2000 watts of output power. It takes very little power to turn a generator which has little or no load.
3) Your power recovery BS is a strawman tactic. Just more smoke and mirrors. Don't need to go there. Just show me 1 & 2.
It appears that you don't consider a machine which outputs 2000 watts while needing only 300 watts of input to produce "free" power. More bad math?
