Originally posted by bistander
I have highlighted again some areas you asked about. The guy in Tennessee conducted many many tests on his system. He is a single guy who only worked as a truck driver when he wanted to. The rest of the time he spent doing research on alternative energy. Primarily the 3BGS and various kinds of generators to use with the 3BGS system. I don't have any of the results of his tests but I think some of them are buried in this thread somewhere. You would have to look back in probably the first half of this thread to find those results. But he was very convinced that he got longer run times using the 3BGS.
You are correct that this is not a practical system for most people to use to power their home. It just takes too much attention and time to keep everything in balance and working correctly. But there are very many things that are not practical. That doesn't mean they don't work! It is certainly possible to run your home by using steam power to turn a generator. And that of course will work. But for most people that is just not practical or worth the trouble. But as far as the loads constantly changing that can be dealt with. That is just a simple engineering problem that can be met several ways. But again all that is not practical.
For those reasons listed above, no I am not using the 3BGS for anything useful. But I have proven to myself that it does work. Saying something is not practical is not the same as saying it doesn't work. If nothing else the 3BGS is a great learning experiment. And if you were living off the grid it could very well mean the difference between success and failure at providing your own source of power.
I am surprised you did not see any benefit from pulse charging batteries. This method of charging lead acid batteries has been around a while. But the frequency of the pulses and the voltage and current of them all play a part in the success or failure of the charging process. The commercial charger I have uses a microprocessor to monitor the battery and adjust the pulses accordingly.
I have been very busy with family matters for several months now. I am hoping to get some time to work with the boost circuit here in the hopefully near future. IF I get time to work on that I will provide all the data I can about what I find. I know Matt and Dave personally. I know what they have told me that I have had time to verify has been true.
It is fine that you don't want to spend time on the 3BGS. But it is certainly NOT fine that you want to keep claiming it doesn't work when you haven't tried it.
I understand what you are saying about the newer Lithium base batteries. But they have their problems also. I use them regularly in my RC airplanes. The power to weight ratio is amazing. But, I have never had a lead acid battery catch fire while in operation. And I have personally had that happen with one of my Lithium batteries. The plane took off just fine and at about 100 feet in the air there was a sudden explosion and the plane came tumbling down. The battery was blown out to the plane and landed on the ground. And as you are probably aware the fire of a burning Lithium battery is very hard to put out as they burn so hot. Of course it eventually burned up. I only charge mine in a special fireproof bag made just for that purpose. Any source of stored energy has the potential to be dangerous.
Respectfully,
Carroll
