New Year
It's a couple minutes after midnight where I am, so here's my first post of the new year. Just something for you all to think about. I have spouted so much stuff over the last eight or so years on the forum that I honestly can’t remember if I have ever discussed the theory behind the research into batteries I have done. Anyway, I thought I would throw it out here for all the naysayers to have a field day with, correcting my grammar, use of terms and whatever other mistakes I happen to make.
First, let’s look at what we’ve been taught. We put a volt meter on a battery to measure how much energy is contained in it. Then we hook up a load to the battery, say a modified Matt motor, and eventually that motor slows down and stops. We say the battery is “dead” because the motor has used up all the energy in the battery, and now it needs to be recharged. We have been taught that the electrical energy in the battery was converted into mechanical energy that caused the motor to turn. But what if most of that is WRONG?
What if the meter is actually measuring the (potential) DIFFERENCE between the positive and negative side of the battery. And what if that energy stored in the battery is like water, and wants to seek its own level. So that when we connect the motor, the energy from one side of the battery runs THROUGH the motor to the other side of the battery, equalizing. The potential difference is now way lower, so our meter shows very little difference between the two sides. There is NO MOVEMENT of current between one side of the battery and the other, so nothing to make the motor run anymore, and it slows to a stop. The energy is still THERE. It hasn’t been used up, or at least MOST of it hasn’t. Some was converted to heat, but MOST of it is still there. It’s just equalized between the two sets of plates in the battery. No movement of energy ( from one side of the battery to the other) means nothing you connect to the battery will run. To move it all back to one side we hook up a charger and FORCE the energy back to one side, unbalancing the battery and reestablishing the potential difference.
Can I prove any of this? Funny you should ask. If you DO run your motor and it slows and comes to a stop, you would not expect it to suddenly run again would you? Here’s an experiment for the more experienced researcher who can take all the proper SAFETY precautions. Batteries can explode, so don’t try this at home unless you know what the heck you are doing. Take a small battery that only holds a volt or two. Connect its negative to the negative of your “dead battery. Now connect your motor between the positive of your dead battery and the small, low voltage battery. What happens? WHY does it happen?
It happens because the “potential difference” between your “dead” battery and the small, low voltage battery was enough to make the motor run. There was still a WHOLE LOT of energy in your battery, but it wouldn’t move from the side it was on to the other side because the two sides were about equal. But the higher voltage of your “dead” battery was still a MUCH higher potential than the small, low voltage battery. So the motor ran. If you put a load on the lower voltage battery at the same time, it will discharge as fast as it charges and that’s a much safer way to test.
This is the basis for all the work I have done on the 3 Battery system, and what led to an understanding of how electricity REALLY works. Class dismissed
